Hi, I have a Rhino model that I would like to use in Radiance. What type of file should I export it to?Thank you,Alejandro
Hi, Alejandro,
Google "radiance photon mapping" tells us the following link:
http://www.ise.fraunhofer.de/en/admin-folder/archiv/applied-optics-and-functional-surfaces-draft/lighting-technology/lighting-simulations/light-directing-with-radiance-photon-mapping/download-photon_mapping/download-photon-mapping
- Ji
On Wed, Feb 5, 2014 at 11:44 PM, Alejandro Pacheco Diéguez < [email protected]> wrote:
Thank you,
Alejandro_______________________________________________
My typical process is to export to .obj, then use the command obj2rad. When you export to obj, be sure to tick the box to export materials, so that any material names you've assigned in Rhino carry over into the rad files. Also, the -f option for obj2rad tends to keep each surface contiguous (rather than triangulating further than the obj export).
From: Alejandro Pacheco Diéguez [mailto:[email protected]]
Sent: Wednesday, February 05, 2014 10:45 AM
To: [email protected]
Subject: [Radiance-general] Rhino to Radiance
Thank you,
Alejandro
Have you tried the open source project in grasshopper called Ladybug?
contiguous (rather than triangulating further than the obj export).*From:* Alejandro Pacheco Diéguez [mailto:[email protected]]
*Sent:* Wednesday, February 05, 2014 10:45 AM
*To:* [email protected]
*Subject:* [Radiance-general] Rhino to RadianceHi,
Alejandro
systems are scanned for acceptability of content and viruses_______________________________________________
Thank you Chien Si for mentioning Ladybug.
Alejandro, You can use Honeybee which is a part of Ladybug plugin (
Ladybug Tools - Grasshopper) to prepare the geometry and
write the files (sky files, rad files for the geometry and materials).
There are components to create the materials and assign them to the
geometry.
I haven't announced the release for Honeybee yet but you can download it
form the github repository: GitHub - ladybug-tools/honeybee-legacy: 🐝 Honeybee is a free and open source plugin to connect Grasshopper3D to EnergyPlus, Radiance, Daysim and OpenStudio for building energy and daylighting simulation
Currently you can run rtrace and rpict lines from the runDaylightAnalysis
components. The project is open source though and you can modify the code
to suite the purpose of your study or you can develop a new component to
run forward raytracing simulations from Honeybee/Ladybug. The latter sounds
perfect to me! ;).
I can send you an example file if that helps.
Mostapha
On Wed, Feb 5, 2014 at 12:48 PM, Chien Si Harriman <[email protected] > wrote:
On Wed, Feb 5, 2014 at 7:53 AM, Christopher Rush < > [email protected]> wrote:
Alejandro
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
