Hello everybody,
is it possible to calculate the RGB irradiance values from a HDR-image
(generated by Rpict)?
So I'm trying to use the "photographic film/sensor" of the "camera" as a
photosensor.
I am trying to do use a HDR image, since I want to apply various masks on
the HDR image.
So I am trying to cut out various sections of my photographic film, and
placing a photosensor / lux-meter on the cut-out sections of the
photographic film.
I was hoping to use something like this:
rmagic basic.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct > output1a
rmagic basic.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct | rcalc -e
'$1=(0.67*$1+0.265*$2+0.065*$3)*179' > output1b
rmagic mask1.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct > output2a
rmagic mask1.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct | rcalc -e
'$1=(0.67*$1+0.265*$2+0.065*$3)*179' > output2b
rmagic mask2.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct > output3a
rmagic mask2.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct | rcalc -e
'$1=(0.67*$1+0.265*$2+0.065*$3)*179' > output3b
Tip, tricks and suggestions are very welcome!
Thanks in advance,
Dolf Bakker
Hi Dolf,
If your hdr image is created using rpict with the -i option than you can
use pvalue to extract the pixel irradiance values.
pvalue -da -h -H basic.hdr > basic_RGB.txt
If you just want to apply masks you can use pcomb with if statements like
this:
pcomb -e 'ro=if(ri(2),ri(1),0);go=if(gi(2),gi(1),0);bo=if(bi(2),bi(1),0)'
basic.hdr mask1.hdr > basic_mask1.hdr
If your hdr images were not generated using rpict -i you could use vwrays
and rtrace to generate the illuminance data files for your image:
vwrays -x 500 -y 500 -vf view.vf | rtrace -i -ab 3 scene.oct > output.txt
Hope this helps,
Andy
On Tue, Aug 6, 2013 at 7:25 AM, Dolf Bakker <[email protected]> wrote:
Hello everybody,
photosensor.
the HDR image.
photographic film.
Thanks in advance,
Dolf Bakker
Hi Dolf,
is it that you want to trace rays for image pixels dependent on their pixel value? So something like "if (pixel_red >=.5) then rtrace pixel_origin pixel_direction"? For that, you can use rcalc, which understands float triples (aka pixels values) as input, and can output either valid origin/direction vectors or nul-vectors depending on the input.
Hello everybody,
is it possible to calculate the RGB irradiance values from a HDR-image (generated by Rpict)?
So I'm trying to use the "photographic film/sensor" of the "camera" as a photosensor.
I am trying to do use a HDR image, since I want to apply various masks on the HDR image.
So I am trying to cut out various sections of my photographic film, and placing a photosensor / lux-meter on the cut-out sections of the photographic film.
rmagic basic.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct | rcalc -e '$1=(0.67*$1+0.265*$2+0.065*$3)*179' > output1b
rmagic mask1.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct | rcalc -e '$1=(0.67*$1+0.265*$2+0.065*$3)*179' > output2b
rmagic mask2.hdr | rtrace \-i+ \-dv \-h\- \-ab 3 scene.oct | rcalc -e '$1=(0.67*$1+0.265*$2+0.065*$3)*179' > output3b
Thanks in advance,
Dolf Bakker
Thanks for the response.
Andrew, your subjects are what I was looking for.
Though I am still not there yet ... However, first I’ll try to play a
little more with it.
Lars, unfortunately that's not what I'm trying. When I made some more
progress and I am better capable to describe the problem, then I'll send
you a small update.
Thanks again!
Dolf
On Wed, Aug 7, 2013 at 10:56 AM, Lars O. Grobe <[email protected]> wrote:
Hi Dolf,
Hello everybody,
photosensor.
the HDR image.
photographic film.
'$1=(0.67*$1+0.265*2\+0\.065\***3)*179' > output1b
'$1=(0.67*$1+0.265*2\+0\.065\***3)*179' > output2b
'$1=(0.67*$1+0.265*2\+0\.065\***3)*179' > output3b
Thanks in advance,
Dolf Bakker
Radiance-general@radiance-**online.org<[email protected]>
http://www.radiance-online.**org/mailman/listinfo/radiance-**general<http://www.radiance-online.org/mailman/listinfo/radiance-general>
