If you have a rad file of a piece of furniture, with the furniture origin at 0,0,0, but you want to array it within your model, try the following xform command. Check the manpage of xform and adjust parameters as needed. The rad file to define your individual item must be in the same directory. This example makes a 2x3 array with 40x70 unit spacing starting at x,y,z of 500,200,0. Scripting makes this an easy way to vary your furniture or lighting layout. Leave off the ! if you run xform yourself or directly from a script, or keep the initial ! for the following line within a rad file of its own to include with your scene. Use multiple xform commands with only the first "-t x y z" if your added geometry is not a neat and tidy array.
!xform -t 500 200 0 -a 2 -t 40 0 0 -a 3 -t 0 70 0 singlefurniture.rad
From: [email protected] [mailto:[email protected]] On Behalf Of Jia Hu
Sent: Thursday, July 15, 2010 4:16 PM
Subject: Re: [Radiance-general] revising geometry
Hello Jack:
I create the majority part of the geometry in Revit and then export the geometry to Radiance. In Radiance, I will add some other geometries (not complicated), such as lighting, blinds , simple furniture and windows. Another reason I want to know the coordinates is that when I adjust some view parameters such as the view point I also need to know the coordinate.
Thank you,
Jia
On Thu, Jul 15, 2010 at 4:07 PM, Jack de Valpine <[email protected]<mailto:[email protected]>> wrote:
Hi Jia,
How did you create your geometry? What kinds of changes are you trying to make? Depending on the extend of the changes, updates or modifications it probably makes much more sense to use a 3D modeling application to make these changes and then re-export the geometry to Radiance.
-Jack de Valpine
# Jack de Valpine
# http://www.visarc.com<http://www.visarc.com/>
Jia Hu wrote:
Hello:
If I intend to revise the model in Radiance, I need to know the coordinate so that I can transform or generate new geometry.
My current methods of checking coordinates are
(1) using rvu option "trace" to see the coordinate of the image.
(2) export rad to other software to view the geometry (I saw a recent post by
Randolph to discuss about "Radiance Geometry Export", but I have not tried)
Is there a better way to show the x, y z axis in the image of Radiance and easily check the
coordinate? What is your practice of adding or revising geometry in Radiance?
Thank you for sharing your experience,
Jia
