I am trying to use accelerad to speed up my scene generation. I am trying to implement an arbitrary clipping surface. A simple example I have used is two boxes (box and smallbox) and a clipping plane between them. I need one box to be clipped off (by using the plane as the clipping surface).
where I would like to replace the rtrace command with the accelerad_rtrace one. There seems to be a problem with this because of the -opd parameter from what I could debug (the p parameter specifically).
Any guidance in this problem would be much appreciated.
The -o options allow rtrace to return an arbitrarily-sized collection of data, which isn’t practical on the GPU and probably scales poorly. However, your first rtrace call could probably be accomplished with no reflections (-lr 1), so I don’t see how you gain anything from GPU acceleration. I would suggest that you use accelerad_rtrace only for your second rtrace call to optimize performance.
Thank you for your quick response, your solution worked but now I am faced with another problem, I have been playing around with the -lr and -lw parameters.
There seems to be some noise in the object and its shadow. Do you have any idea why is this happening?
