I am using the 5.1.0.
According to my code that I mentioned before, the "combine.hdr" was
rendered, but it could not be well opened and displayed like other patch
images with ".hdr".
Actually, I have been also trying the method of "rfluxmtx" , then it
returned " cannot load '-o'" when I run bash.
#vwrays -ff -x 600 -y 600 -vf views_up.vf | rfluxmtx @rtc.opt -v -ffc '
vwrays -d -x 600 -y 600 -vf views_up.vf ' -o sky_tre_p%d.hdr - test_sky.rad
-i a.oct
I will appreciate your helping.
Clarence
发件人: Greg Ward <[email protected]>
发送时间: 2017年10月12日 4:19
收件人: Radiance general discussion
主题: Re: [Radiance-general] 答复: Render tregenza sky patches by rcontrib and
pcomb
Hi Clarence,
This should be correct. What version of Radiance do you have? (I.e., what
does "rpict -version" return?)
Does it report any error at all? Is the output file completely empty?
It works when I run it using 5.1, and I'm pretty sure it will work for
anything later than the 4.1 release, which was in 2011.
Date: October 11, 2017 8:15:46 PM PDT
Thanks for the advice.
I have tried, but the "result.hdr" was not a format of picture, which meant
that the rendering was failed.
#gensky 3 21 10 +s -a 22 -o 114 | genskyvec -m 1 -c 1 1 1 > tmp_skydist.dat
#vwrays -ff vw |rcontrib @rtc1\.opt \-ffc (vwrays -d $vw) -V+ -f
tregenza.cal -b tbin -bn Ntbins -o first_tre_p%d.hdr -m skyglow
test_sky_sun.oct
#dctimestep first_tre_p%d.hdr tmp_skydist.dat > combine.hdr
Or, any parameters should be needed in the third line?
Clarence
发送时间: 2017年10月11日 18:09
主题: Re: [Radiance-general] Render tregenza sky patches by rcontrib and pcomb
Hi Clarence,
Rather than trying to fix Axel's old script, it's better to use the simpler
and more efficient dctimestep method:
dctimestep first_tre_p%d.hdr skydist.dat > result.hdr
You can also simplify the rcontrib step using the rfluxmtx program, but what
you have is fine.
Date: October 11, 2017 6:27:45 AM PDT
Dear all,
I've been trying to render the Tregenza sky patches by using rcontrib. Each
patch was rendered successfully, but when I use "pcomb" which contains
"tregsamp.bash" by Axel Jacobs to combine them, the "combined.hdr" was a
black picture.
test_sky_sun.oct
#pcomb -h $(bash apply_tregsamp_1.bash) > combine_1.hdr
#the original bash script below by Axel Jacobs was changed in order to be
consistent with my code.
# Path to the patch images
imgpath="image_fisheye/patches_tre/first_tre"
for i in imgpath\_\*\.hdr; do
\# Scan patch number from file name
patch=(ls $i \
>rcalc -i "imgpath\_p\\$\{pnum\}\.hdr" \\
\-e "\\$1=pnum"\)
\# Get multiplier from dat file, based on record number
multi=(cat tmp_skydist.dat \
>rcalc -e
"diff=$patch-recno+1;absdiff=if(diff,diff,-1*diff);
\$1=if(absdiff,0,\$1);" |total)
echo " -s $multi $i"
done
#EOF
Clarence
