Are you using the latest release? How was it installed? Can someone else test this out, maybe @Axel_Jacobs1 ? I don’t have a Windows machine to install it on.
Yes, I’m using the latest release. I tried to install it both from the zip file and from the executable… same result. Also bringing back the 5.2’s falsecolor.pl presents the same problem.
This is the exact error: C:\Users\Mattia\AppData\Local\Temp\JfOVVgXpz1/slab.hdr: bad picture size C:\Users\Mattia\AppData\Local\Temp\JfOVVgXpz1/scol.hdr: bad picture size write error: Invalid argument
I see that the last slash is a forward one, maybe Windows doesn’t like it?
PS You said “Running falsecolor.exe with the given command line (both, with and without -lw) works fine on my machine”. Actually I’m having problems if I use -lw 0, If I omit the flag or I give it a non-zero value it works for me too.
Hi Mattia, I still can’t replicate the error you are seeing with -lw 0. Works fine for me. In the screenshot you posted, are slab.hdr and scol.hdr valid HDR images that you can open with your HDR viewer?
slab.hdr and scol.hdr are not valid hdr files that I can open (I used https://viewer.openhdr.org/ to check).
I also tried to use it on a different pc using the Radiance Tutorial example files (The room_nice example) to be sure that my input files weren’t corrupted, and the same error comes up.
I also noticed that the error occurs if I set -lw from 0 to 20 included, and it stops when I set a value greater than 21.
These files are indeed messed up. They are 1x1 (single pixel) images with CR-LF sequences that should be just linefeeds. I am not sure how they are being created. Are you sure you are using the latest version of psign, and not some problematic version? Unfortunately, I can’t really debug your problem from here, unless someone else can help you reproduce it.
I tried multiple radiance windows versions’ precompiled binaries, and the same error occurs.
At this point, I think it’s something related to my system, not the software.
Meanwhile, I’ll just remove the legend with ImageMagick when I need to.
Thanks anyway for the great support. I’ll let you know if I understand what’s wrong.
Hi @Greg_Ward, I could recreate the error on my machine. From what I can see in the source code when -lw is less than 20 it is set to 0 to ignore the legend:
Which then means that it tries to create a dummy color scale from some two images that it expects to be in the temp folder. scolpic and slabpic - which it fails to find and that’s why it raises the issue:
When I run the command with a larger value for -lw I can see that the temp folder with all the temp files are created. I can also see all the images being created by running the falsecolor command with no argument while it is waiting for the stdin to provide an input.
PS: I think between the time that the images are created and when you try to read them the temp folder is being deleted so the command cannot find the files when it looks for them.
Wow – didn’t think to look at that! This makes perfect sense, as the code works under Unix, but the linefeeds get changed to CR-LF sequences under Windows.
I checked in a hopefully fixed version just now – you can download it directly here or wait for it to percolate to the installers this weekend.
Axel Jacobs wrote this script, so I can use that as an excuse for not finding this, myself. Thanks, @Mostapha !
