Region rendering
Is there any way with rpict to render a specific rectangular region/crop of a view? Example: have a view specified, and only render the top left quadrant? I checked the man page for rpict, but i could not come up with anything.
Aksel
Aksel Groß
Dipl.Ing.Arch.
Dipl.Szeno.
Electric Gobo
Schönhauser Allee 182
10119 Berlin, Germany
aksel@gobo.io
T +49 30 559 531 75
M +49 179 394 30 92
Hi Askel,
You need to adjust the view to do this. Use -vl an -vs to lift and shift
the view to the upper left and then reduce -vh and -vv accordingly.
Andy
On Wed, Sep 26, 2012 at 11:24 AM, Aksel Groß <aksel@gobo.io> wrote:
anything.
Aksel
Aksel Groß
Dipl.Ing.Arch.
Dipl.Szeno.
Electric Gobo
aksel@gobo.io
T +49 30 559 531 75
M +49 179 394 30 92
Hi Andy,
Thanks! In fact i thought of that for a second, but wasnt aware the shift would work without a distort. I was worried the ie top left and top right part of an image would not fit seamlessly anymore after shifting. But will give it a try now that you recommend it.
Aksel
Am 26.09.2012 um 20:34 schrieb Andrew McNeil <amcneil@lbl.gov>:
Hi Askel,
You need to adjust the view to do this. Use -vl an -vs to lift and shift the view to the upper left and then reduce -vh and -vv accordingly.
Andy
Aksel
Aksel Groß
Dipl.Ing.Arch.
Dipl.Szeno.
Electric Gobo
aksel@gobo.io
T +49 30 559 531 75
M +49 179 394 30 92
You have to carefully determine the -vh and -vv parameters, there's a bit
of trigonometry to be done. But it does work, I've rendered many image
tiles using this method.
Andy
On Wed, Sep 26, 2012 at 11:42 AM, Aksel Groß <aksel@gobo.io> wrote:
Hi Andy,
Aksel
Hi Askel,
Andy
anything.
Aksel
Aksel Groß
Dipl.Ing.Arch.
Dipl.Szeno.
Electric Gobo
aksel@gobo.io
T +49 30 559 531 75
M +49 179 394 30 92
Andy, that is exactly what i wondered - thanks a lot for your answer.
Aksel
Am 26.09.2012 um 20:55 schrieb Andrew McNeil <amcneil@lbl.gov>:
You have to carefully determine the -vh and -vv parameters, there's a bit of trigonometry to be done. But it does work, I've rendered many image tiles using this method.
