Reflectance data
Hello, I use a device to measure the reflectance from 344 to 1045
wavelength,
How could I convert these measured data into Radiance RGB, and how could I
calculate the overall reflectance from the measurement?
I try to use weights of RGB channels in Radiance, but which wavelength out
of 344 - 1045 should I select for each channel?
Jia
You can use the routines defined in src/common/ccolor.h to convert from spectral measurements to a CIE color and from there to RGB:
#include "ccolor.h"
  C_COLOR clr;
  float spec_data[MYNWL];
  float rgb[3];
  double myLuminance = 0.5;
  /* set spec_data array] */
  c_sset(&clr, 344.0, 1045.0, spec_data, MYNWL);
  ccy2rgb(&clr, myLuminance, rgb);
Note that you have to decide the number of wavelengths ahead of time, and they must be evenly spaced.
I've arbitrarily set the overall Y value to 0.5, but of course you set it to what you need. I can't help you with that part.
Subject: [Radiance-general] Reflectance data
Date: September 3, 2014 8:02:35 PM GMT+01:00
Hello, I use a device to measure the reflectance from 344 to 1045 wavelength,
How could I convert these measured data into Radiance RGB, and how could I calculate the overall reflectance from the measurement?
I try to use weights of RGB channels in Radiance, but which wavelength out of 344 - 1045 should I select for each channel?
Jia
Hi Jia,
I have been using mgfilt to convert from spectrally resolved reflectance to rgb.
Jia
