Rcontrib to render reinhart sky patches
Hello all,
I am trying to use vwrays and rcontrib to render sky patches. The code below works fine for the tregenza patches, but cannot render reinhart patches.
vwrays -ff $vw|rcontrib @image.opt -ffc -fo $(vwrays -d $vw) -V+ -f tregenza.cal -b tbin -bn Ntbins -o images/patches/p%d.hdr -m skyglow a.oct
vwrays -ff $vw|rcontrib @image.opt -ffc -fo $(vwrays -d $vw) -V+ -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -o images/patches/p%d.hdr -m skyglow a.oct
Thank you!
Tommy
[Sent from my iPhone]
[http://mlm.polyu.edu.hk/PolyU80_Email_Signature.png]
www.polyu.edu.hk/80anniversary<http://www.polyu.edu.hk/80anniversary>
Disclaimer:
This message (including any attachments) contains confidential information intended for a specific individual and purpose. If you are not the intended recipient, you should delete this message and notify the sender and The Hong Kong Polytechnic University (the University) immediately. Any disclosure, copying, or distribution of this message, or the taking of any action based on it, is strictly prohibited and may be unlawful.
The University specifically denies any responsibility for the accuracy or quality of information obtained through University E-mail Facilities. Any views and opinions expressed are only those of the author(s) and do not necessarily represent those of the University and the University accepts no liability whatsoever for any losses or damages incurred or caused to any party as a result of the use of such information.
Hi Tommy,
Did you try reinhart.cal with MF:1 ?
If that works, you are most likely running up against your system limit on the number of simultaneous open files. The fix for this is discussed a number of times in the archives, and belongs in a FAQ.
See https://www.radiance-online.org/pipermail/radiance-general/2014-March/010137.html
Date: August 8, 2017 8:44:10 AM PDT
Hello all,
vwrays -ff vw|rcontrib @image\.opt \-ffc \-fo (vwrays -d $vw) -V+ -f tregenza.cal -b tbin -bn Ntbins -o images/patches/p%d.hdr -m skyglow a.oct
vwrays -ff vw|rcontrib @image\.opt \-ffc \-fo (vwrays -d $vw) -V+ -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -o images/patches/p%d.hdr -m skyglow a.oct
Thank you!
Tommy
Hi Tommy,
Can you tell us what error you get or describe the result?
When rendering MF4, make sure you increase the number of simultaneous files
that can be open with this command:
ulimit -n 6000
Andy
On Tue, Aug 8, 2017 at 8:44 AM, WEI, Minchen [BSE] <[email protected] > wrote:
Hello all,
patches.
a.oct
Thank you!
Tommy
*Disclaimer:*
*This message (including any attachments) contains confidential
unlawful.*
*The University specifically denies any responsibility for the accuracy or
party as a result of the use of such information.*
Yes, I tried. It always gives me an error "required modifier is missing".
Tommy
Minchen (Tommy) Wei, PhD
(+852)-3400 3606 [email protected]<mailto:[email protected]>
Sent: Wednesday, 9 August 2017 10:34 AM
Subject: [WARNING: SUSPECTED SPAM]Re: [Radiance-general] Rcontrib to render reinhart sky patches
Hi Tommy,
See https://www.radiance-online.org/pipermail/radiance-general/2014-March/010137.html<https://secure-web.cisco.com/1VWBuBCL2c4oc--8y2PuBRIXllcWklIl9l04WklgqEgOUN00VUZdU2ytY_eigJ93eZf5kUhxpGZoGRL7ocuOuEP3hbWJPsJkE5bQbw_3MVYYZHu871QXJJGmCWMBGtvdSGz_-pT2WArKL2H4A8b2E9PAvSO7TQJSsH7qX8-hheMnYiQeKxNFCcfPondyZNjk4aG7O43bEt316QeUEsEAy6r_1QM0r9fxlv1KXX7RFfi9qm03zXgZwlcrkhfLuhnO2QTN6lUMlM4LguwutPYZRHJGiYMjZxNtlVdoyLaD1xdUekT-MUSCmG5SItPBdxTh-/https%3A%2F%2Fwww.radiance-online.org%2Fpipermail%2Fradiance-general%2F2014-March%2F010137.html>
From: "WEI, Minchen [BSE]" <[email protected]<mailto:[email protected]>>
Hello all,
Thank you!
Tommy
Disclaimer:
OK, thanks. It does (usually) help to tell us what error you are getting, rather than simply saying "it doesn't work."
In this case, I don't understand why you would be getting such an error. Your command *looks* alright as you have shared it. Are you certain there are no special characters or newlines where there shouldn't be one?
Try cutting and pasting the command from your e-mail. If it still isn't working, you may have to send me your files in a private message so I can try to reproduce the error, which makes no sense.
Date: August 8, 2017 7:42:34 PM PDT
Yes, I tried. It always gives me an error “required modifier is missing”.
Tommy
Hi Tommy,
Hello all,
Thank you!
Tommy
