rcontrib output format options
Hello!
I'd like to extract the three-phase-method matrices in a human redeable format (view and daylight). How can I do this? I've tried the option -faa in rcontrib but I get problems reading the cal files.
rcontrib: fatal - command line error at 'klems_int.cal'
rcontrib: fatal - command line error at 'reinhart.cal'
Thank you!
Bruno
Bruno,
These cal files do not come in the library folder by default. Have you put
them there? They are in ray/src/cal/cal, if I am not wrong.
hope it works!
2013/10/1 Bruno Bueno <[email protected]>
Hello!
Thank you!
Bruno
Radiance-general@radiance-**online.org<[email protected]>
http://www.radiance-online.**org/mailman/listinfo/radiance-**general<http://www.radiance-online.org/mailman/listinfo/radiance-general&gt;
Bruno,
It seems that there is a problem with your command line. It's tough to tell
exactly without seeing it, but my guess is that you've done something like
this:
-faa klems_int.cal
but it should be two seperate options like this:
-faa -f klems_int.cal
If this isn't the problem pleas send the full command and we'll have a
better chance at troubleshooting.
Andy
On Tue, Oct 1, 2013 at 7:07 AM, Bruno Bueno <[email protected]>wrote:
Hello!
Thank you!
Bruno
Hi German,
Yes, I put them there, so I can modify them. I'm using the 3pm and it works fine by using -f option in rcontrib (i.e. working with binary matrices?). Now I'd like to work with the matrices outside Radiance. Any ideas? Thank you!
Bruno
Hi Andy,
Yes, that was the problem. Now it works!
Thanks a lot for the help!
Bruno
