Hi German,
Not sure this belongs on dev (vs general), but:
genBSDF runs fine on Mavericks/10.9. What are you using for your "activity monitor"? When I just use top, it will report an rcontrib process for every core I have requested, using ~97% of CPU. What are you using to monitor this, and what command are you using?
On 8/11/14, 11:12 AM, "CHI-German Molina" <[email protected]<mailto:[email protected]>> wrote:
Dear People,
I am using genBSDF (rcontrib) trying to use my 4 threads (multi threaded dual core), but my activity monitor show only about 30% usage of each virtual core.
It is the first time I check this on OSx Mavericks, but it used to use 100% on the previous OSx version. I checked on issues realted to the OS, but I did not find anything.
Is this affecting rcontrib´s performance? Can I do anything to make this better?
THANKS IN ADVANCE!
Germán Molina L.
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445
Nota de Confidencialidad: Este mensaje incluído los archivos adjuntos son confidenciales y pueden contener informacion privilegiada protegida por ley. Si Ud. no es el destinatario, deberia abstenerse de copiarlo, distribuirlo, divulgarlo o usar la informacion contenida. Por favor, avise inmediatamente al emisor y borre este mensaje de su sistema. Los mensajes electronicos son susceptibles de ser cambiados, infectados o adulterados sin autorizacion. No asumimos responsabilidad alguna por ninguna clase de cambios o sus consecuencias. Usted debe estar informado que la compania puede hacer un seguimiento de sus mensajes electronicos y su contenido, gracias.
Confidentiality Notice: The information contained in this email message, including any attachment, is confidential and is intended only for the person or entity to which it is addressed. If you are neither the intended recipient nor the employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that you may not review, retransmit, convert to hard copy, copy, use or distribute this email message or any attachments to it. If you have received this email in error, please contact the sender immediately and delete this message from any computer or other data bank, Thank you.
A informação transmitida é confidencial e para conhecimento exclusivo do destinatário. Sua utilização, não autorizada, constitui crime passível de prisão. Todas as precauções possíveis foram tomadas para garantir que este e-mail não contenha vírus. Uma vez que nossa empresa não pode assumir responsabilidade por nenhuma perda ou dano causado por este e-mail ou de seus anexos, recomendamos que o destinatário utilize seus procedimentos de antivírus antes de qualquer uso.
