Rob,
I am not sure where it belongs either, haha.
I am using the OSx activity monitor (mine is in spanish, so I am
translating the title). My processes are running at 25-30%.
My command is:
genBSDF -n 4 -t4 7 -c XXXXX ./Model/Black.mat ./model/SHading.rad >
BSDF/shading.xml
THANKS VERY MUCH!
2014-08-11 13:54 GMT-04:00 Guglielmetti, Robert <
[email protected]>:
Hi German,
Not sure this belongs on dev (vs general), but:
genBSDF runs fine on Mavericks/10.9. What are you using for your
"activity monitor"? When I just use top, it will report an rcontrib process
for every core I have requested, using ~97% of CPU. What are you using to
monitor this, and what command are you using?
On 8/11/14, 11:12 AM, "CHI-German Molina" <[email protected]<mailto: >>> [email protected]>> wrote:
Dear People,
I am using genBSDF (rcontrib) trying to use my 4 threads (multi threaded
dual core), but my activity monitor show only about 30% usage of each
virtual core.
It is the first time I check this on OSx Mavericks, but it used to use
100% on the previous OSx version. I checked on issues realted to the OS,
but I did not find anything.
Is this affecting rcontrib´s performance? Can I do anything to make this
better?
THANKS IN ADVANCE!
Germán Molina L.
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445
Nota de Confidencialidad: Este mensaje incluído los archivos adjuntos
son confidenciales y pueden contener informacion privilegiada protegida por
gracias.
Confidentiality Notice: The information contained in this email message,
Radiance-dev mailing list
*Germán Molina L.*
Ingeniero Trainee
*Nota de Confidencialidad:* Este mensaje incluído los archivos adjuntos
gracias.
*Confidentiality Notice:* The information contained in this email
message, including any attachment, is confidential and is intended only for
the person or entity to which it is addressed. If you are neither the
intended recipient nor the employee or agent responsible for delivering
this message to the intended recipient, you are hereby notified that you
may not review, retransmit, convert to hard copy, copy, use or distribute
this email message or any attachments to it. If you have received this
email in error, please contact the sender immediately and delete this
message from any computer or other data bank, Thank you.
