rcontrib malloc error
I'm running view matrix calculations using rfluxmtx/rcontrib for the 3-phase method and keep getting one of two errors:
1)
rcontrib(2346) malloc: *** mmap(size=a really big number) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
rcontrib: system - out of memory in samp_hemi: Cannot allocate memory
rcontrib: system - read error from render process
Killed: 9
2)
Killed: 9
I can't establish a pattern for why/when these two errors occur.
Oddly, I don't always get the error with some gridpoint files (with 5900 points), but I consistently get it with another gridpoint file (with 7500 points). I don't understand why grid size would influence memory though...?
System is Mac OS 10.7.5 (2 x 6-core); error repeats on my laptop with Yosemite installed
Latest Radiance HEAD release; although the error repeats on older versions from 6 months ago
rcontrib settings are: -n 12 -ab 12 -ad 100000 -lw 1e-5 -I+
Any clues on why I'm getting these errors?
Thank you!
Galen
I'm currently struggling with memory issues -- of the volatile and non-volatile kind -- trying to get Radiance to play nicely on a server-based optimization framework, and making it Windoze-friendly. As a result of that last bit, I'm writing view/daylight matrices in ASCII, and they get large in a hurry. 7500 points worth of matrix, for a presumably annual (8760) input, is a BAF (big a** file).
I'm not seeing your errors specifically Galen, mine are all downstream; I either run out of disk space or hit memory errors when rfluxmtx tries to read these BAFs into memory for merging. But maybe we're both barking up the same tree in a sense? I dunno. But now you know why I have a headache today.
On 3/17/16, 2:39 PM, "Galen Burrell" <[email protected]<mailto:[email protected]>> wrote:
1)
Killed: 9
2)
Killed: 9
Thank you!
Galen
Hi Rob,
I don't think rfluxmtx reads large matrices into memory. It could write a too-large matrix to disk as the output of rcontrib, but neither process holds the matrices in memory. Maybe you meant rmtxop? That will hold two double (64-bit) color (x3) matrices in memory at a time, which could be a problem for certain very large matrices. You might try dctimestep for matrix multiplication. It uses float (32-bit) color (x3) arrays, so half as much memory is required. Also, it's more clever about skipping zero rows and columns in your matrix, which is good for daylight calculations that include nighttime hours.
Subject: Re: [Radiance-general] rcontrib malloc error
Date: March 17, 2016 1:57:36 PM PDT
1)
Killed: 9
2)
Killed: 9
Thank you!
Galen
Hi Galen,
I've never seen rcontrib run out of memory in this way before. What are your rendering options for rcontrib? Do any of your surfaces have greater than 100% reflectance or transmittance? This could cause the number of rays to increase rather than decrease on multiple bounces, which could lead to exponential memory growth during ray tree evaluation.
Subject: [Radiance-general] rcontrib malloc error
Date: March 17, 2016 1:39:45 PM PDT
I’m running view matrix calculations using rfluxmtx/rcontrib for the 3-phase method and keep getting one of two errors:
1)
*** error: can’t allocate region
rcontrib: system – out of memory in samp_hemi: Cannot allocate memory
rcontrib: system – read error from render process
Killed: 9
2)
Killed: 9
I can’t establish a pattern for why/when these two errors occur.
Oddly, I don’t always get the error with some gridpoint files (with 5900 points), but I consistently get it with another gridpoint file (with 7500 points). I don’t understand why grid size would influence memory though…?
rcontrib settings are: –n 12 –ab 12 –ad 100000 –lw 1e-5 –I+
Any clues on why I’m getting these errors?
Thank you!
Galen
Thanks man! I did mean rmtxop, and I will give that dctimestep idea a go!
On Mar 17, 2016, at 3:45 PM, Greg Ward <[email protected]> wrote:
Hi Rob,
1)
Killed: 9
2)
Killed: 9
Thank you!
Galen
Just an update on this error: After searching through my materials definitions per Greg's suggestion, I found that I had a glass definition of 95% light transmission, which resulted in a transmissivity of > 1. Doh! After reducing the light transmission to something more sensible I stopped getting the error. Thanks Greg!
Date: Thu, 17 Mar 2016 14:49:01 -0700
Content-Type: text/plain; charset="windows-1252"
Hi Galen,
I?m running view matrix calculations using rfluxmtx/rcontrib for the 3-phase method and keep getting one of two errors:
1)
(error code=12)
*** error: can?t allocate region
rcontrib: system ? out of memory in samp_hemi: Cannot allocate memory
rcontrib: system ? read error from render process
Killed: 9
2)
Killed: 9
I can?t establish a pattern for why/when these two errors occur.
Oddly, I don?t always get the error with some gridpoint files (with 5900 points), but I consistently get it with another gridpoint file (with 7500 points). I don?t understand why grid size would influence memory though??
Yosemite installed Latest Radiance HEAD release; although the error
repeats on older versions from 6 months ago rcontrib settings are: ?n
12 ?ab 12 ?ad 100000 ?lw 1e-5 ?I+
Any clues on why I?m getting these errors?
Thank you!
Galen
Thanks for the update; I figured it was something like that since I saw
this commit right around the time of this thread:
63250
Hi Galen,
1)
(error code=12)
Killed: 9
2)
Killed: 9
memory though??
Thank you!
Galen
Good catch, Galen! I'm glad you found the explanation. Meanwhile, I changed the code so that (hopefully) we won't get runaway ray counts even if there are surfaces with >100% reflectance or transmittance.
Cheers!
Date: March 23, 2016 5:48:33 AM PDT
Hi Galen,
1)
(error code=12)
Killed: 9
2)
Killed: 9
Thank you!
Galen
Galen,
Here is something else that might improve the quality of your gridpoint calculations. I have seen "-lw 1e-5" to be inadequate in most daylit spaces. I usually drop this to around 1e-9 (and using high -ad settings) and get much better results when applying daylight coefficients to sky patches (the results are typically higher). When using a method where the direct sun is removed from a sky coefficient calculation that includes both sun and sky, to be added in via a third phase, this will generally also avoid the presence of negative numbers in the final results. You can easily test the -lw setting to see if it makes a difference.
Rick Mistrick
Sent: Wednesday, March 23, 2016 11:21 AM
Cheers!
Hi Galen,
1)
(error code=12)
Killed: 9
2)
Killed: 9
Thank you!
Galen
Galen,
I'd like to add that Rick is exactly right. An additional note: -lw is more
important for big spaces than small spaces.
--Tim
On Tue, Mar 29, 2016 at 8:27 AM, Richard Mistrick <[email protected]> wrote:
Galen,
Rick Mistrick
Cheers!
> From: Galen Burrell <[email protected]>
> From: Greg Ward <[email protected]>
> Hi Galen,
> -Greg
>> 1)
>> (error code=12)
>> Killed: 9
>> 2)
>> Killed: 9
though??
>> Thank you!
>> Galen
