rcontrib for rendering - missing required modifier argument
Hello Greg,
This is the command line:
C:\Radiance\test\20150505>vwrays -ff -vf -vtv -vh 94 -vv 70 -vp 1.5 5 1.75
-vd 0
-1 0 -x 600 -y 600 | rcontrib "vwrays -vtv -vh 94 -vv 70 -vp 1.5 5 1.75
-vd 0 -
1 0 -x 600 -y 600 -d" -ffc -fo -o vmx/window_%03d.hdr -f klems_ang.cal -b
kbinS
-bn Nkbins -m windowglow -ab 2 12 -ad 50000 -lw 2e-5 model_vmx.oct
-vtv: no view in file
rcontrib: fatal - missing required modifier argument
I attach you the window.rad file (material + geometry)
Urtza.
Greg Ward <gregoryjward@gmail.com> escribió:
Can you show us the command line that reports an error, exactly as you
are giving it? (Cut and paste if you can.)
   SUBJECT: [Radiance-general] rcontrib for rendering - missing
   DATE: May 6, 2015 2:38:37 AM PDT
I have problems with rcontrib program with Windows 8 SO. I am trying to do
Example 1 of A McNeil The Three-Phase Method. I would like to render with
vwrays with a windowglow in a test room. However, missing required modifier
argument message script. Does anyone know what is the problem with the
modifier?
Thank you in advance,
Kind regards,
Urtza.
window.rad (204 Bytes)
Thank you very much!
I will try to follow your indications.
Best wishes,
Urtza.
Hi Urtza,
The problem is the use of double-quotes for "vwrays -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0 -1 0 -x 600 -y 600 -d", which used singe back-quotes under Unix. This replaces the command with its output on the command line, something Windows does not do. Substituting with double-quotes is the wrong thing to do. Instead, execute this command yourself, then cut and paste the output into the rcontrib command line in its place.
The output is "-x 600 -y 392 -ld-", so you would use:
  vwrays -ff -vf -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0-1 0 -x 600 -y 600 | rcontrib -x 600 -y 392 -ld- -ffc -fo -o vmx/window_%03d.hdr -f klems_ang.cal -b kbinS -bn Nkbins -m windowglow -ab 2 12 -ad 50000 -lw 2e-5 model_vmx.oct
As the actual command in Windows.
Subject: Re: [Radiance-general] rcontrib for rendering - missing required modifier argument
Date: May 7, 2015 12:19:37 AM PDT
Hello Greg,
C:\Radiance\test\20150505>vwrays -ff -vf -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0
-1 0 -x 600 -y 600 | rcontrib "vwrays -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0 -
1 0 -x 600 -y 600 -d" -ffc -fo -o vmx/window_%03d.hdr -f klems_ang.cal -b kbinS
Urtza.
Can you show us the command line that reports an error, exactly as you are giving it? (Cut and paste if you can.)
Subject: [Radiance-general] rcontrib for rendering - missing required modifier argument
Date: May 6, 2015 2:38:37 AM PDT
I have problems with rcontrib program with Windows 8 SO. I am trying to do Example 1 of A McNeil The Three-Phase Method. I would like to render with vwrays with a windowglow in a test room. However, missing required modifier argument message script. Does anyone know what is the problem with the modifier?
Kind regards,
Urtza.
I tried following your indications and it worked, although, I had to remove
Nkbins because it is undefined variable. I do not way but it could be not
having such as the Tregenza skydiscretization...
I removed and thus, the default number is 0:
  C:\Radiance\test>vwrays -ff -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0 -1 0
-x 600
klems_an
  g.cal -b kbinS -bn Nkbins -m windowglow -ab 12 -ad 50000 -lw 2e-5
model_vmx.oct
  rcontrib: Nkbins`RC: undefined variable
   C:\Radiance\test\20150505>vwrays -ff -vtv -vh 94 -vv 70 -vp 1.5 5 1.75
-vd 0 -1
   0 -x 600 -y 600 | rcontrib -x 600 -y 392 -ld -ffc -fo -o
vmx/window_%03d.hdr -m
   windowglow -ab 12 -ad 50000 -lw 2e-5 model_vmx.oct
However, generated window_000.hdr file does not have light. It is a black
image, even though, the render generated by rvu of the room it is ok.
Do you know why does it happen?
Thank you!
Kind regards,
Urtza
----- Mensaje reenviado de urtza.uriarte@upc.edu -----
Fecha: Thu, 07 May 2015 19:35:42 +0200
De: urtza.uriarte@upc.edu
Asunto: Re: [Radiance-general] rcontrib for rendering - missing required
modifier argument
Para: Radiance general discussion <radiance-general@radiance-online.org>
Best wishes,
Urtza.
Hi Urtza,
    vwrays \-ff \-vf \-vtv \-vh 94 \-vv 70 \-vp 1\.5 5 1\.75 \-vd 0\-1 0 \-x
model_vmx.oct
modifier argument
Hello Greg,
1.75 -vd 0
-vd 0 -
kbinS
Urtza.
modifier argument
the modifier?
Kind regards,
Urtza.
----- Terminar mensaje reenviado -----
What do you use to view the HDR image? Try typing:
ximage -e auto window_000.hdr
This will automatically adjust the exposure of your image upon initially opening the file. It could be that your image does have non-zero values but the exposure is skewed in your viewpoint making it look black with the default exposure value.
Or type
ximage window_000.hdr
then hit the ‘a’ key while ximage is active to view it with automatic exposure
while ximage is active you can also hit the ‘=’ key and click a point in the image to adjust the exposure according to various points in the image
However, generated window_000.hdr file does not have light. It is a black image, even though, the render generated by rvu of the room it is ok.
Thank you!
Kind regards,
Urtza
From: urtza.uriarte@upc.edu [mailto:urtza.uriarte@upc.edu]
Sent: Wednesday, May 13, 2015 5:01 AM
Hello Christopher,
Thank you for your response.
I think that in the radiance-4.2.2-win32.exe there is not the ximage
program. I usually use RadianceIV.exe program from Ecotect.
C:\Radiance\test\20150505\vmx>ximage window_000.hdr
"ximage" no se reconoce como un comando interno o externo,
programa o archivo por lotes ejecutable.
  However, I find klems_full.cal file that it has all information about
kbinS and Nkbins.
Now I have 145 .hdr files. They have light source, but the room walls are
black (is it usual?)
In reference to /pcompos,/ window1_*.hdr is invalid argument. Do you know
why?
  C:\Radiance\test\20150505\vmx\images>pcompos -a 10 -b 1 1 1
"window1_*.hdr" > al
  lwindow1.hdr
  window1_*.hdr: Invalid argument
Kind regards,
Urtza.
   Or type
automatic
exposure
point
     FROM: urtza.uriarte@upc.edu [mailto:urtza.uriarte@upc.edu]
SENT: Wednesday, May 13, 2015 5:01 AM
ok.
Thank you!
Kind regards,
Urtza
Thanks!
Now, I will try to solve the problem with /pcompos /(window1_*.hdr,
invalid argument)
  C:\Radiance\test\20150505\vmx\images>pcompos -a 10 -b 1 1 1 window1_*.hdr
al
  lwindow1.hdr
Best wishes!
Urtza.
Hi Urtza,
  You should not be using the file "klems_ang.cal" but something like
"klems_full.cal" or klems_int.cal. This is why Nkbins was undefined,
and probably at least one reason your simulation is not working.
   SUBJECT: Re: [Radiance-general] Fwd: rcontrib for rendering -
   DATE: May 13, 2015 8:14:16 AM PDT
  Hello Christopher,
kbinS and Nkbins.
why?
  lwindow1.hdr
Kind regards,
Urtza.
   Or type
automatic
exposure
point
ok.
Thank you!
Kind regards,
Urtza
Welp, it appears that the '*' wildcard expansion does not work with Windows in the standard shell, even though the wildcard does work with other internal commands, such as 'type' (Windows-speak for 'cat'). As they say: WTF?
P.S. The wildcard does expand correctly with pcompos in a Cygwin shell, so there's that.
P.P.S. You can install a lightweight Cygwin shell by simply installing Git for Windows (https://msysgit.github.io/). You get a proper BASH shell in Windows with minimal effort. Highly recommended.
On 5/15/15, 9:23 AM, "Greg Ward" <gregoryjward@gmail.com<mailto:gregoryjward@gmail.com>> wrote:
I'm probably not the one to answer this, as I don't use Windows and haven't seen this error, but did you check to make sure there are files that match "window1_*.hdr" in the directory where pcompos is executed?
From: urtza.uriarte@upc.edu<mailto:urtza.uriarte@upc.edu>
Date: May 14, 2015 2:51:37 AM PDT
Thanks!
Now, I will try to solve the problem with pcompos (window1_*.hdr, invalid argument)
C:\Radiance\test\20150505\vmx\images>pcompos -a 10 -b 1 1 1 window1_*.hdr > al
lwindow1.hdr
Best wishes!
Urtza.
Greg Ward <gregoryjward@gmail.com<mailto:gregoryjward@gmail.com>> escribió:
Hi Urtza,
You should not be using the file "klems_ang.cal" but something like "klems_full.cal" or klems_int.cal. This is why Nkbins was undefined, and probably at least one reason your simulation is not working.
From:urtza.uriarte@upc.edu<mailto:urtza.uriarte@upc.edu>
Subject: Re: [Radiance-general] Fwd: rcontrib for rendering - missing required modifier argument
Date: May 13, 2015 8:14:16 AM PDT
Hello Christopher,
I think that in the radiance-4.2.2-win32.exe there is not the ximage program. I usually use RadianceIV.exe program from Ecotect.
However, I find klems_full.cal file that it has all information about kbinS and Nkbins.
Now I have 145 .hdr files. They have light source, but the room walls are black (is it usual?)
In reference to pcompos, window1_*.hdr is invalid argument. Do you know why?
C:\Radiance\test\20150505\vmx\images>pcompos -a 10 -b 1 1 1 "window1_*.hdr" > al
lwindow1.hdr
Kind regards,
Urtza.
Christopher Rush <Christopher.Rush@arup.com<mailto:Christopher.Rush@arup.com>> escribió:
Or type
then hit the 'a' key while ximage is active to view it with automatic exposure
while ximage is active you can also hit the '=' key and click a point in the image to adjust the exposure according to various points in the image
From:urtza.uriarte@upc.edu<mailto:urtza.uriarte@upc.edu> [mailto:urtza.uriarte@upc.edu]
Thank you!
Kind regards,
Urtza
Radiance-general@radiance-online.org<mailto:Radiance-general@radiance-online.org>
The "cmd" shell does not do filename expansion; commands that support it
do it themselves--"cmd" is quite minimal. To make that pcompos command
work, it would have to be provided with the full list of files, spelled
out. This could be done in Windows PowerShell or perhaps via some
combination of command. Anyone who knows Windows scripting well willing
to provide an alternative?
Randolph
On 5/15/2015 8:55 AM, Guglielmetti, Robert wrote:
Thanks!
lwindow1.hdr
Best wishes!
Urtza.
Hi Urtza,
Hello Christopher,
lwindow1.hdr
Kind regards,
Urtza.
Or type
Thank you!
Kind regards,
Urtza
Randolph M. Fritz, Lighting Design and Simulation
+1 206 390 4477 || rmfritz3@panix.com
Rob,
Getting off-topic, but not sure if it warrants a separate thread... you imply that we can run Radiance commands in the Git for Windows bash shell. Is there an advantage to doing so, in comparison to Cygwin (which I have used in the past)? Both would have the clear advantages of being able to use more powerful scripted commands when compared to the Windows cmd prompt, but Git-bash is more lightweight while Cygwin would be more powerful (for things unrelated to Radiance?)? In both cases install according to normal Windows Radiance installation and adjust paths as necessary in each environment?
-Chris
From: Guglielmetti, Robert [mailto:Robert.Guglielmetti@nrel.gov]
Sent: Friday, May 15, 2015 11:55 AM
