rcontrib for rendering - missing required modifier argument
Hi Urtza,
You should not be using the file "klems_ang.cal" but something like "klems_full.cal" or klems_int.cal. This is why Nkbins was undefined, and probably at least one reason your simulation is not working.
Best,
-Greg
Subject: Re: [Radiance-general] Fwd: rcontrib for rendering - missing required modifier argument
Date: May 13, 2015 8:14:16 AM PDT
Hello Christopher,
Thank you for your response.
I think that in the radiance-4.2.2-win32.exe there is not the ximage program. I usually use RadianceIV.exe program from Ecotect.
C:\Radiance\test\20150505\vmx>ximage window_000.hdr
"ximage" no se reconoce como un comando interno o externo,
programa o archivo por lotes ejecutable.
However, I find klems_full.cal file that it has all information about kbinS and Nkbins.
Now I have 145 .hdr files. They have light source, but the room walls are black (is it usual?)
In reference to pcompos, window1_*.hdr is invalid argument. Do you know why?
C:\Radiance\test\20150505\vmx\images>pcompos -a 10 -b 1 1 1 "window1_*.hdr" > al
lwindow1.hdr
window1_*.hdr: Invalid argument
Thank you in advance,
Kind regards,
Urtza.
Christopher Rush <[email protected]> escribió:
What do you use to view the HDR image? Try typing:
ximage -e auto window_000.hdr
This will automatically adjust the exposure of your image upon initially opening the file. It could be that your image does have non-zero values but the exposure is skewed in your viewpoint making it look black with the default exposure value.
Or type
then hit the ‘a’ key while ximage is active to view it with automatic exposure
while ximage is active you can also hit the ‘=’ key and click a point in the image to adjust the exposure according to various points in the image
Sent: Wednesday, May 13, 2015 5:01 AM
However, generated window_000.hdr file does not have light. It is a black image, even though, the render generated by rvu of the room it is ok.
Do you know why does it happen?
Thank you!
Kind regards,
Urtza
