Rcalc if(cond,then,else)
Dear list,
I'd like to use Pvalue to pipe an image in to Rcalc and divide each pixel's Red value by its Blue value. If the latter ratio is greater/equal to .6 then I'd like make the given pixel white and if not then black. I'm using the following Pvalue command:
pvalue -o -h -H image.hdr
The if(cond,then,else) function is eluding me
Thanks as always.
Chris
Christian Humann ~ Associate
LOISOS + UBBELOHDE
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
On May 29, 2012, at 3:49 PM, Guglielmetti, Robert wrote:
Yeah Randolph, this is very cool, and a nice application of HDRI in the real world. Might be worth posting a link to this on the HDRI list as well.
Sent: Friday, May 25, 2012 4:56 PM
Subject: Re: [Radiance-general] OT: A study of LCD display luminance
Randolph,
Thank you very much for sharing nice study. It's interesting results. Last time, I relied on the LCD manufacturer brightness specs or nit number to model and I was not sure whether it was a correct method.
Additionally, in your first image, may i know how you set the brightness setting in your computer? was it in maximum/100% brightness setting?
Thank you,
Eddy Santosa
On Fri, May 25, 2012 at 3:22 PM, Randolph M. Fritz <RFritz@lbl.gov<mailto:RFritz@lbl.gov > >> wrote:
For a simulation, I wanted to include some LCD displays. Problem was, I didn't know how bright they actually were. So I did an HDR photographic study of mine. I thought some of you might be interested, so I've put it up online. If you are interested, you can see the results here:
http://elad.lbl.gov/index.php/Interior_Applications/Display_Luminance/L226W
Randolph M. Fritz
Radiance-general@radiance-online.org<mailto:Radiance-general@radiance-online.org>
Hi Chris,
The "pcomb" program was built for this kind of thing. Try:
  pcomb -e 'lo=if(0.6*bi(1)-ri(1),0,1)' input.hdr | ra_tiff -b - black_white.tif
I didn't use a ratio so as to avoid divid-by-zero errors, and converted the (monocrhome) output to TIFF.
Date: May 30, 2012 12:08:11 PM PDT
Dear list,
Thanks as always.
Chris
