Dear all,
The man page for rcalc says "By default, tabs and spaces are ignored except
as field separators". I wonder if there is a way to overrule this default
behavior. For example:
echo 1,2,3 4,5 | rcalc -t, -e '$1=if($2-$1,$3,0)' gives '3' as result. Can
it be forced to give '3 4'?
In this case the space is not a field separator, but it causes the rest of
the field be missing from the ouput.
Many thanks,
Victor Lopez-Rioboo Gil
Hi Victor,
I am not sure there is a way to do what you are asking with rcalc. You can use input fields rather than separators with an input format, e.g.:
rcalc -i '\{n1\},{n2},\(s3\),{n4}'
This loads the first two comma-separated values as numbers, the third as a string, and the fourth as a number again. (This is the difference between using curly braces and parentheses in rcalc format fields.) However, there is not much you can do with string fields other than repeat them in the output. They cannot be the arguments or results of any expressions or formulas. Generally, they are simply used as place-holders or a means to repeat the input in the output using a similarly constructed output format (-o option).
You could use the "cond" variable to decide whether to output a record or not in your example, like so:
rcalc -i '\{n1\},{n2},\(s3\),{n4}' -e 'cond=n2-n1' -o '$(s3)'
This would only output the third field when the second is greater than the first. It would not output "0" otherwise, but no line at all.
I don't know if this helps.
Date: June 6, 2017 7:02:59 AM PDT
Dear all,
The man page for rcalc says "By default, tabs and spaces are ignored except as field separators". I wonder if there is a way to overrule this default behavior. For example:
echo 1,2,3 4,5 | rcalc -t, -e '$1=if($2-$1,$3,0)' gives '3' as result. Can it be forced to give '3 4'?
In this case the space is not a field separator, but it causes the rest of the field be missing from the ouput.
Many thanks,
Hi Victor,
If you are using linux or mac, this sort of thing is simple with awk. There
might be an equivalent with windows.
echo 1,2,3 4,5 | awk -F, '{if($2>$1)print $3;else print 0}'
output:
3 4
Andy
On Tue, Jun 6, 2017 at 7:49 AM, Greg Ward <[email protected]> wrote:
Hi Victor,
(-o option).
*Date: *June 6, 2017 7:02:59 AM PDT
Dear all,
Many thanks,
