I am a student from Bristol University in the UK currently rendering a scene
which includes a desk lamp with a halogen bulb.
The bulb is similar to the one at the following address:
http://www.lightworld.com/MERCHANT2/merchant.mv?Screen=PROD
<http://www.lightworld.com/MERCHANT2/merchant.mv?Screen=PROD&Product_Code=97
88&Category_Code=halogen> &Product_Code=9788&Category_Code=halogen
I am trying to replicate the reflective, transparent inner surface of the
light cone, does anyone have any ideas on how I can make the mirror material
have a degree of transparency so I can accurately represent light leaving
the rear of the bulb.
Many thanks in advance,
Tom Wood
Use trans as the alternate type in mirror with appropriate parameters.
Date: December 2, 2004 11:26:28 AM PST
I am a student from Bristol University in the UK currently rendering a scene which includes a desk lamp with a halogen bulb.
http://www.lightworld.com/MERCHANT2/merchant.mv?Screen=PROD&Product_Code=9788&Category_Code=halogen
I am trying to replicate the reflective, transparent inner surface of the light cone, does anyone have any ideas on how I can make the mirror material have a degree of transparency so I can accurately represent light leaving the rear of the bulb.
Tom Wood
Thanks Greg,
Unfortunately not getting any love using that, although I did accidentally
come across a slightly better result by applying the mirror material to
itself using the code below, not sure why!
void mirror lamp_bulb_outer_material
1 lamp_bulb_outer_material
3 0.9 0.9 0.9
The surface I'm trying to apply the material to is an imported mesh, could
that be a reason that adding the transparency to the mirror material isn't
working? The code I've tried is below if it helps:
void trans lamp_bulb_outer_transparency
7 .9 .9 .9 .01 .01 .5 .5
1 lamp_bulb_outer_transparency
3 .9 .9 .9
lamp_bulb_outer_material mesh lamp_bulb_outer_object
1 lamp_bulb_outer.rtm
Thanks again,
Tom
From: Gregory J. Ward [mailto:gregoryjward@gmail.com]
Sent: 02 December 2004 22:40
To: Radiance general discussion; Tom.Wood.01@bristol.ac.uk
Subject: Re: [Radiance-general] Radiance Transparent Mirror Material
Tom Wood
No virus found in this incoming message.
Checked by AVG Anti-Virus.
Version: 7.0.289 / Virus Database: 265.4.4 - Release Date: 30/11/2004
Hi Tom,
I'm not sure why using a mirror as its own alternate would do anything -- the code says it should be the same as not specifying an alternate....
That said, there's little point is specifying a mirror material for a mesh surface. It should behave just like trans at that point -- it won't create any virtual sources, which is presumably why you would use 'mirror' in the first place. Virtual sources only get created for planar surface types: 'polygon' & 'ring'. Any other surface type (including meshes) just get treated normally.
For a 90% reflective material with 10% transmission, the following 'trans' should work:
void trans mirror_mat
7 .92 .92 .92 .9 0 1 1
