I noticed a difference in the sky brightness near the horizon depending on whether I use a sky subdivision or not. I expected that the brightness of each sky patch in the Reinhart subdivision would be the average brightness of the Perez sky in that region. What I’m finding is that this is mostly true, but not near the horizon. I wonder if someone can explain.
Here’s an example of what I’m looking at. The method here was to render the sky dome in a 180-degree fisheye view using gendaylit/rpict and then gendaymtx/vwrays/rcontrib/dctimestep, and then compare the difference images.
Here’s the gendaymtx sky minus the gendaylit sky:
And here’s the gendaylit sky minus the gendaymtx sky:
As you can see, pretty much every patch is half brighter and half darker in the gendaymtx sky compared to the gendaylit sky, which makes sense. The problem is the ring of patches closest to the horizon, which are uniformly brighter in the gendaymtx sky than in the gendaylit sky. The biggest difference I’ve seen (not including the four patches closest to the sun) is over 10,000 cd/m^2.
For the record, here’s how I’m generating the gendaylit sky:
gendaylit 1 18 9.5 -W 689 60 -a 44.88 -o 93.23 -m 90 1>sky_1_18_9.5.rad
echo skyfunc glow sky_mat 0 0 4 1 1 1 0 1>>sky_1_18_9.5.rad
echo sky_mat source sky 0 0 4 0 0 1 180 1>>sky_1_18_9.5.rad
oconv sky_1_18_9.5.rad 1>sky_1_18_9.5.oct
rpict -vta -vh 180 -vv 180 -vp 0 0 0 -vd 0 0 1 -vu 0 1 0 sky_1_18_9.5.oct 1>sky_1_18_9.5.hdr
And here’s how I’m generating the gendaymtx sky:
gendaymtx -m 1 -c 1 1 1 -of USA_MN_Minneapolis-St.Paul.wea > sky.smx
echo rvu -vta -vp 0 0 0 -vd 0 0 1 -vu 0 1 0 -vv 180 -vh 180 -vo 0 -va 0 -vs 0 -vl 0 > up.vf
vwrays -vf up.vf -x 512 -y 512 -d > view.txt
vwrays -ff -vf up.vf -x 512 -y 512 | rcontrib view.txt -ffc -fo -o images/vmx/patch_%%04d.hdr -bn 1 -b “if(-Dx0-Dy0-Dz*1,0,-1)” -m ground_mat -f reinhartb.cal -p MF=1 -b rbin -bn Nrbins -m sky_mat -ab 8 -ad 50000 -lw .00002 -lr -10 sky_1_18_9.5.oct
dctimestep -o images/tstep/tstep%%04d.hdr images/vmx/patch_%%04d.hdr sky.smx
Merry Christmas,
Nathaniel
