Radiance on Cygwin: Starting problems
I'm not sure if this applies to Windows, but is your DISPLAY environment variable set to launch X11 when you invoke rvu? I'm way out of my league here, but I know that if I try running rvu from my Mac OSX Terminal app without the DISPLAY variable set, no dice. If I run rvu from my X11 app, it works - I assume it is because in X11, the default display is X window.
Again, I ain't no Windows person, so I'm shooting from the hip here.
kirk
On Mar 4, 2006, at 7:18 PM, Ramana Koti wrote:
Hey,
Thanks Kirk, I had made the "void bright light" mistake which I corrected to successfully create the octree file.
Coming to the second error:
$rview -vp 2.25 .375 1 -vd -.25 .125 -.125 -av .5 .5 .5 test.oct
I get a windows pop up error message saying rvu.exe - Unable to locate component, This application has failed to start because cybX11-6.dll was not found. Re-installing the application may fix this problem.
My installation folder "C:\radiance_stuff\cygwin\usr\X11R6\bin" contains only a run.exe file and nothing else. I rerun the setup with X11R6 selected and the message at the end says "nothing needed to be installed". Does that mean the file is missing from the installation itself? What can I do to correct the situation?
Ramana.
