Hey,
Thanks Kirk, I had made the "void bright light" mistake which I corrected to successfully create the octree file.
Coming to the second error:
$rview -vp 2.25 .375 1 -vd -.25 .125 -.125 -av .5 .5 .5 test.oct
I get a windows pop up error message saying rvu.exe - Unable to locate component, This application has failed to start because cybX11-6.dll was not found. Re-installing the application may fix this problem.
My installation folder "C:\radiance_stuff\cygwin\usr\X11R6\bin" contains only a run.exe file and nothing else. I rerun the setup with X11R6 selected and the message at the end says "nothing needed to be installed". Does that mean the file is missing from the installation itself? What can I do to correct the situation?
Ramana.
On 3/4/06, *Kirk Thibault* <[email protected] > <mailto:[email protected]>> wrote:
On page 21 of RwR, the input file <room.rad> specifies a light
definition of:
# this is the material for my light source
void light bright
3 100 100 100
The structure for the definition is
MODIFIER TYPE ID
3 R G B
i.e., "light" is the type and "bright" is the id.
Make sure you did not accidentally type:
"void bright light" [that is, switched "bright" and "light" by
accident] on the first line of the definition.
Hope this helps, been there done that!
Kirk
On Mar 4, 2006, at 6:11 PM, Ramana Koti wrote:
> Hello,
> I am a graduate student at Arizona State University and I am going
> to use Radiance for my thesis. The computer maintenance guy at
> school here helped me install Cygwin on my notebook computer and
> Radiance on top of it. I have just begun to learn Radiance and when
> I input a simple room as specified in the Introduction chapter
> 1.3.1 of the book "Rendering with Radiance" by Greg Ward Larson and
> Rob Shakespeare, I get the following errors:
> $ oconv room.rad > test.oct
> oconv: fatal - <room.rad>: unknown type "bright"
> this problem.
> I used the NoteTab Light text editor to create the file room.rad.
> Any advice on how to proceed will be greatly appreciated. If
> somebody with working knowlege of Cygwin/Radiance lives around
> Tempe/Phoenix/Mesa (Arizona State), I would like to get my notebook
> computer to you to make sure everything needed is installed
> properly. Please help.
> Regards,
> Venkata Ramana Koti
> MS in Building Design (Energy/Climate)
> School of Architecture and Landscape Architecture
> College of Design
> Arizona State University, Tempe AZ 85287
> Radiance-general mailing list
> [email protected]
> http://www.radiance-online.org/mailman/listinfo/radiance-general
Venkata Ramana Koti
1137 E Orange St Apt #35
Tempe AZ 85281 USA
Tel: 480.326.9275
College of Design
# Jack de Valpine
