Radiance in virtual Win 10
Hi radiance community,
I just tried to install radiance (NREL binaries 5.1.0) in a clean windows 10 64 bit virtual machine (Fusion 8.5.8). When I start a program from the command line I get the error "The application was unable to start correctly 0xc000007b".
Does anybody have an idea what is going wrong here? There are a lot of hints on the net concerning this error. But I did not find the right one yet.
Many thanks and best regards
Martin
Lichttechnik Martin Klingler
Spraidt 7
5271 Moosbach
AUSTRIA
Tel ++43-7724-443833
Fax ++43-7724-443838
email [email protected]
Are you getting this error for all the Radiance executables you try, or
just one or more specific ones?
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
I did not check systematically. But I get it for rpict, rtrace, ies2rad, obj2rad, genclock, gendaylit, total, rlam, icalc, rcontrib, getinfo ... I have the feeling I will get it for all.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Re: [Radiance-general] Radiance in virtual Win 10
Sent:
Montag, 30. Oktober 2017 02:21
Guglielmetti, Robert ([email protected])
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Yeah, that sounds like a broader problem. =/ We have had some issues of
late, getting all the executables to work properly on Windows. Changes to
Qt versions and compilers have fixed some problems and introduced others.
We are working on it as we can, but for now your best bet is to use the
previous installer release (5.0.a.12), which you can grab here:
have the
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Well that is a step. I just tested it, and I do not have the same error - that is fine.
But - I try to setup a virtual machine with Rhino/Grasshopper/Honeybee[+] and for that the latest version 5.1.0 is necessary. If Mostapha is reading this - is that true?
Looks like I have to find another solution.
Thank you very much in any case
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
Montag, 30. Oktober 2017 17:34
have the
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Unless Honeybee et al. tools are using the photon map stuff, there isn’t
much difference between 5.0.a.12 and 5.1.0 that would absolutely require
the latter. Mostapha, what’s the verdict there? I can try to expedite a
5.1.1 if you really need that version...
that is fine.
reading this -
is that true?
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
Release 5.0.a.12 · NREL/Radiance · GitHub
<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.c
om%2FNREL%2FRadiance%2Freleases%2Ftag%2F5.0.a.12&data=02%7C01%7Crobert.gug
lielmetti%40nrel.gov%7C036b126a5c88496687e608d51fc9fa9d%7Ca0f29d7e28cd4f54
84427885aee7c080%7C0%7C0%7C636449874712339144&sdata=wBLrLkuQIzLiJAq0mauVf%
2BJsT5PdlmEB5p5KNLdlD%2FM%3D&reserved=0>
have the
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
Guglielmetti, Robert (R
<mailto:[email protected]>obert.Guglie
<mailto:[email protected]>[email protected]
<mailto:[email protected]>)
windows
the
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.radi
ance-online.org%2Fmailman%2Flistinfo%2Fradiance-general&data=02%7C01%7Crob
ert.guglielmetti%40nrel.gov%7C036b126a5c88496687e608d51fc9fa9d%7Ca0f29d7e2
8cd4f5484427885aee7c080%7C0%7C0%7C636449874712339144&sdata=ikmi54c0EWaFOcv
2BGTT%2FyRB4yI1eL9eRlPAfBW1vpE%3D&reserved=0>
Hi Rob and Martin,
Honeybee[+] doesn't currently deal with photon mapping. Version 5.0.a.12
should work fine with Honeybee[+].
Mostapha
On Mon, Oct 30, 2017 at 3:30 PM, Guglielmetti, Robert < [email protected]> wrote:
>that is fine.
>reading this -
> is that true?
>Martin
>Spraidt 7
>5271 Moosbach
>AUSTRIA
>Original Message
>Subject:
>Sent:
>From:
>>have the
>>Martin
>>Spraidt 7
>>5271 Moosbach
>>AUSTRIA
>>Original Message
>>Subject:
>>Sent:
>>From:
>>- Rob
>>>windows
>>>the
>>>command
>>>0xc000007b".
>>>yet.
>>>Martin
>>>Spraidt 7
>>>5271 Moosbach
>>>AUSTRIA
>_______________________________________________
>[email protected]
data=02%7C01%7Crob
fa9d%7Ca0f29d7e2
Hi Rob and Mostapha,
that sounds great. I am out all the day but I will test as soon as possible and report back. Thank you very much.
Martin
gesendet mit Consolidate Mobile
Original Message
Subject:
Mostapha Sadeghipour Roudsari ("[email protected]")
Hi Rob and Martin,
Honeybee[+] doesn't currently deal with photon mapping. Version 5.0.a.12 should work fine with Honeybee[+].
Mostapha
attachedFile.txt (185 Bytes)
On Mon, Oct 30, 2017 at 3:30 PM, Guglielmetti, Robert <[email protected]> wrote:
that is fine.
reading this -
is that true?
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
have the
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
windows
the
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
version 5.0.a.12 seems to run without any problems. Thank you very much for your support.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
Dienstag, 31. Oktober 2017 02:17
Mostapha Sadeghipour Roudsari ([email protected])
Hi Rob and Martin,
Honeybee[+] doesn?t currently deal with photon mapping. Version 5.0.a.12 should work fine with Honeybee[+].
Mostapha
that is fine.
reading this -
is that true?
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
have the
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
Original Message
Subject:
Sent:
windows
the
command
0xc000007b".
yet.
Martin
Spraidt 7
5271 Moosbach
AUSTRIA
