I am using desktop radiance2.0b on windows. As I need to simulate a room
with a deep lightpipe, I would like to use the photon map but I can't find
any version of it I can use on windows.
Is there anything I can do?
Cordialement,
Valère Paupelin-Huchard
t (+33) 1.78.42.73.91
m (+33) 6.63.87.63.70
f (+33) 1.78.42.73.95
Elioth (Iosis Concept)
Groupe Egis
4, rue Dolorès Ibarruri / TSA 80006
F-93188 Montreuil Cedex
-----Message d'origine-----
De : radiance-general-request@radiance-online.org
[mailto:radiance-general-request@radiance-online.org]
Envoyé : samedi 26 mars 2011 20:00
À : radiance-general@radiance-online.org
Objet : Radiance-general Digest, Vol 85, Issue 13
radiance-general-owner@radiance-online.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Radiance-general digest..."
Today's Topics:
1. Re: Radiance-general Digest, Vol 85, Issue 12 (David Appelfeld)
Message: 1
Date: Fri, 25 Mar 2011 12:22:02 -0700
Subject: Re: [Radiance-general] Radiance-general Digest, Vol 85, Issue
12
Message-ID:
<AANLkTim9SpW_H6dEtrKuWs8JB7bthbqXHeb3zsiPpDWf@mail.gmail.com>
Hello Rob,
I have figured it out yesterday night. I tried to use Grag's compiled
version and it is working. My problem was that I was not aware that I did
not copied the compiled version to the /usr/local/bin.
I guess I also get it compiled by self, so I can share it with the list.
The probelem was that makefile can not locate GL/gl.h directory which is
probably called OpenGL on OSX after searching google. However I could get
the GL/gl.h and just copied it either to /usr/include or to unpacked
evalglare into geometry directory.
Then in "makefile" I changed
CFLAGS = -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 $(DEBOPT) -Wall
to
CFLAGS = -g -fnested-functions -DPICT_GLARE -DFLOAT=double -O3 $(DEBOPT)
-Wall
and it seems that it got program compiled. I did not tested because I think
it is better to use Grag's compiled version.
Probably there will be more correct and elegant way to do it but I guess
this is working to.
Thank you
David
radiance-general@radiance-online.orgTo subscribe or unsubscribe via the World Wide Web, visit
radiance-general-request@radiance-online.orgYou can reach the person managing the list at
radiance-general-owner@radiance-online.orgWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of Radiance-general digest..."Today's Topics:
1. installing evalglare (David Appelfeld)
2. Re: installing evalglare (Rob Guglielmetti)----------------------------------------------------------------------
Message: 1
Date: Thu, 24 Mar 2011 20:59:03 -0700
Subject: [Radiance-general] installing evalglare
Message-ID:
<AANLkTim3Rmmd0=ht0UTbr4qrHMvfKC0YShRVSbNyheFW@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"Daer List, I am trying compile evalgrale on OSX but I am getting
following error. I am sure that it is quite trivial problem since I am
not much familiar with compiling programs. Did anyone had such a
problem or can someone advice me how to install it correctly or maybe
I just should move unpacked program to right directory and run it
there. I could find missing file GL/gl.h in Mesa 3-D graphics package
and copy it to the /usr/include where it should probably be, but by
this only first part of error was solved (above the line).
Thank you very much for any advices.
DavidDavid:evalglare Dave$ make
gcc -c -g -DMSDOS -DPICT_GLARE -DFLOAT=double -O3 -Wall -o
pictool.o pictool.c -I. -Igeometry In file included from pictool.h:12,
from pictool.c:1:
geometry/g3affine.h:14:19: error: GL/gl.h: No such file or directory
from pictool.c:1:
geometry/g3affine.h:26: error: syntax error before 'GLdouble'
geometry/g3affine.h:27: error: syntax error before 'GLdouble'----------------------------------------------------------------------
pictool.c: In function 'read_exposure':
pictool.c:89: error: nested functions are disabled, use
-fnested-functions to re-enable
pictool.c: In function 'pict_read_fp':
pictool.c:228: warning: unused variable 'ex'
pictool.c: In function 'pict_write_fp':
pictool.c:519: warning: unused variable 'argv'
pictool.c:518: warning: unused variable 'argc'
make: *** [pictool.o] Error 1
-------------- next part -------------- An HTML attachment was
scrubbed...
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/
20110324/135d527e/attachment-0001.html
Message: 2
Date: Fri, 25 Mar 2011 09:05:26 -0600
From: Rob Guglielmetti <rob.guglielmetti@gmail.com>
Subject: Re: [Radiance-general] installing evalglare
Message-ID:
<AANLkTi=yBarcOWZA9DUm+12UiocYu0aee4kWaRmKiNF6@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"Hello,
Greg Ward managed to get evalglare to compile back in '09 at the
Radiance Workshop. I don't recall what changes he made to make it
happen, but he got it to work. It appears that this compiled
executable is contained in the OS X binary archive available for
download from www.radiance-online.org. I have had a few "bus error"s
when using this version, but it works on many images.
Maybe you could try that version? Option B is to use the windows
version on a VM, which is what I usually do.- Rob
On Thu, Mar 24, 2011 at 9:59 PM, David Appelfeld > <d.appelfeld@gmail.com > >wrote:
following
> error. I am sure that it is quite trivial problem since I am not
> much familiar with compiling programs. Did anyone had such a problem
> or can someone advice me how to install it correctly or maybe I just
> should move unpacked program to right directory and run it there. I
> could find
missing
> file GL/gl.h in Mesa 3-D graphics package and copy it to the
> /usr/include where it should probably be, but by this only first
> part of error was
solved
> (above the line).
> David
> pictool.h:12,
> from pictool.c:1:
> from pictool.c:1:
-fnested-functions
> to re-enable
> Radiance-general@radiance-online.org
scrubbed...
URL: <
20110325/efff60c7/attachment-0001.html
http://www.radiance-online.org/mailman/listinfo/radiance-generalEnd of Radiance-general Digest, Vol 85, Issue 12
URL:
<http://www.radiance-online.org/pipermail/radiance-general/attachments/20110
325/f33e9977/attachment-0001.html>
End of Radiance-general Digest, Vol 85, Issue 13
