Ciao Thomas,
thank you for your reply.
So you really want to know internal illuminance values?for a given
scene for the whole year? (I hope you know?you can get the external
illuminance from the epw file.)
R: I know I can get the external illuminace from epw file but no all
locations have these data values (if you open ITA_Cagliari Elmas you
can see it is that)
I think if I consider the Illuminance values taken from epw file I
can use gensky and insert them as -B and -R parameters (dividing them
to 179, before) and add +s when I have both values and -c when I have
only the diffuse Illuminance. (Can you confirm it?)
My summary of your problem:
Your idea is to use Daysim (or Radiance) with a climat data file to
calculate the internal illuminance values and plug these into E+ or
whatever. Your first step is to calculate external values in an
empty
scene to "validate" your sky model. Doing this in Daysim and
Radiance
(with gendaylit) you got two sets of results with significant
differences.
I did it as you write.
I hope you did have a -I option in there some where. You also only
need to increase your "-ab" to 1 to get the "diffuse" part.
I used -I option.
Now the interesting bit:
If you look at your results or the global horizontal values you
will
see that the Daysim values are roughly 25%-30% higher than those
calculated in Radiance. However, they are consistently higher
(which
is good). I would expect that the difference is a result of the
approach the two applications have:
Why is good to get higher values?
1) Daysim calculates a sky component and just maps the sky onto
this
distribution to get a particular result.
2) Radiance used the sky directly in it's raytracing calculation.
Both sets of results are bound to be different from the actually
observed illuminance on the ground. You can extract the illuminance
values from the EPW file and compare them to the calculated
results.
If you find that one of the sets is reasonably accurate go with
that.
I did it and there is a small difference between epw and daysim data
illuminance (about 2-3%), so I suppose I can use illuminance values
provided by Daysim.
So, using the same input (Irradiance values comes from epw file) the
sky created by Daysim works better than a sky generated by gendaylit?
Iin which conditions can I use gendaylit?
So, if i want to show particular illuminance condition in radiance (i.
e. 12:00 on 21 March) by mean a falsecolor image with illuminace
values, is better to use gensky with +s or -c
depending on if there is direct and diffuse illuminance or only
diffuse one, using the illuminance data values from daysim or epw (if I
have it)?
If my weather file has not illuminance data values, I must use Daysim
to generate the illuminace external values and use them in Radiance to
make analysis (by means gensky); I can`t use gendaylit (starting from
Irradiance value provided by the weather file) because it provides
illuminance values are not correct compared to measured ones.
Can you confirm it?
You can also use the measured values to 'calibrate' your
calculations
and scale the internal results according to a reference calculation
outside. If your reference point value is different from the EPW
record you increase or decrease the calculated illuminance to
compensate for the overall difference.
Ok, I can do it if I have measured data.
Sorry for many questions and thanks a lot in advance.
Ciao
Roberto
End of Radiance-general Digest, Vol 84, Issue 6
Supera i limiti: raddoppia la velocità da 10 a 20 Mega! Risparmia con Tutto Incluso: telefono + adsl 20 mega a soli 29,95 € al mese per due anni!SCONTO DI 240 EURO!http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso/?WT.mc_id=01fw
