Hi Thomas,
Thank you very much for your helpful response.
Regarding the gendaylit, I use the Radiance 3R9 for CYGwin. My environment variable RAYPATH is .:/opt/radiance/lib.
Do you mean I have to change the direction of the RAYPATH to execute the gendaylit command successfully?
Also I'm not sure which parameter I have to use for the -W parameter. I used -W 280 280, but maybe this is my mistake.
Can you explain me what is the meaning of these two values?
Thank you very much in advance.
Marion
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Wednesday, October 06, 2010 3:01 PM
To: [email protected]
Subject: Radiance-general Digest, Vol 80, Issue 3
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
1. gensky and gendaylit (Kerl, Marion (SCR US EXT))
2. Re: gensky and gendaylit (Thomas Bleicher)
Message: 1
Date: Wed, 6 Oct 2010 07:04:46 -0700
From: "Kerl, Marion (SCR US EXT)" <[email protected]>
Subject: [Radiance-general] gensky and gendaylit
To: <[email protected]>
Message-ID:
<1F994EE20CC4154DBB59DDE3100F906B0474BAF9@USNWK102MSX.ww017.siemens.net>
Hi everyone,
I have questions regarding the commands gensky and gendaylit:
1. I generate with 'gensky 2 5 15 -a 37.42 -o 122.4 -m 120' this
file:
# gensky 2 5 15 -a 37.42 -o 122.4 -m 120
# Local solar time: 14.61
# Solar altitude and azimuth: 24.9 41.9
# Ground ambient level: 11.7
void light solar
3 5.75e+06 5.75e+06 5.75e+06
solar source sun
4 -0.605853 -0.675230 0.420723 0.5
void brightfunc skyfunc
2 skybr skybright.cal
7 1 5.44e+00 1.16e+01 3.62e-01 -0.605853 -0.675230 0.420723
Now I have some questions about the
generated parameters:
What is the ground ambient level?
How is the Solar altitude generated?
What is the '2 skybr skybright.cal' in the third part 'void brightfunc skyfunc' meaning?
And why is the third line in every part 0??
2. When I want to call this command 'gendaylit 2 5 15 -a 37.42 -o
122.4 -m 120 -W 280 280 -g .1' I will get this error:
C:\cygwin\opt\radiance\bin\gendaylit.exe 2 5 15 -a 37.42 -o
file coeff_perez.dat cannot be opened
lect_coeff_perez does not work
Does everyone of you know why I get this error?
Because the file gendaylit.exe is already in the folder C:\cygwin\opt\radiance\bin\.
Marion
URL: http://radiance-online.org/pipermail/radiance-general/attachments/20101006/3deb986b/attachment.html
Message: 2
Date: Wed, 6 Oct 2010 09:32:40 -0500
Subject: Re: [Radiance-general] gensky and gendaylit
Message-ID:
<[email protected]>
Content-Type: text/plain; charset=windows-1252
Morning.
On Wed, Oct 6, 2010 at 9:04 AM, Kerl, Marion (SCR US EXT) <[email protected]> wrote:
Hi everyone,
1. I generate with 'gensky 2 5 15 -a 37.42 -o 122.4 -m 120' this file:
# gensky 2 5 15 -a 37.42 -o 122.4 -m 120 # Local solar time: 14.61 #
Solar altitude and azimuth: 24.9 41.9 # Ground ambient level: 11.7 [
Now I have some questions about the generated parameters:
An indication for the values of the '-av' option of rpict and rtrace.
If you wanted to use '-av' to represent the ambient light level of an exterior scene you would set the values to something in the range of 11.7.
The first three parameters of your gensky line are month, day and time. You further specify the location's latitude and longitude with '-a' and '-o'. The sun position and altitude are calculated from these values.
skyfunc' meaning?
The output of gensky is basically a brightness distribution definition for a sky dome. The brightness is defined by a function in the file 'skybright.cal'.
That's the standard notation for Radiance materials (and other objects). You have a base definition (like in 'solar' above) which does not need any advanced options or parameters. Then there is advanced definition of 'skyfunc' which adds two parameters on the second line - that's why it starts with a '2'. I don't know if the third line is used at all in Radiance but I expect they had plans for it back in the days when it was defined. For now it just says '0' to indicate that there are no further arguments on this line.
122.4 -m 120 -W 280 280 -g .1' I will get this error:C:\cygwin\opt\radiance\bin\gendaylit.exe 2 5 15 -a 37.42 -o 122.4 -m
120 -W 280 280 -g .1file coeff_perez.dat cannot be opened
lect_coeff_perez does not workDoes everyone of you know why I get this error? Because the file
Do you have a file called 'C:\cygwin\opt\radiance\lib\coeff_perez.dat' ?
Do you have an environment variable called 'RAYPATH' in your Cygwin environment?
Which version of Radiance are you using?
End of Radiance-general Digest, Vol 80, Issue 3
