In your example, you test the irradiance at a single point in *only one
direction* (up) which is not what I am trying to do unfortunately. If I
want to calculate the energy arriving at a point on a plane, calculating
irradiance from a single direction isn't realistic. Thus, I asked about
RSENSOR which you recommended that I use a long time ago. I am thinking
that for each point, I call RTRACE with the view direction -vd changing in
equal increments and then add the irradiances. For example, the view
directions for a very rough calculation would be in spherical
coordinates/degrees: (1, 0, 0), (1, 90, 0), (1, 180, 0), (1, 270, 0), (1,
0, 45), (1, 90, 45), (1, 180, 45), (1, 270, 45), (1, 0, 90).
Also, I am confused about "a list of RGB irradiance values (watts/sr/m^2)."
This looks like radiance, and reputable sources state that the units for
irradiance are (W/m^2).
Thank you!
Valerie
On Dec 28, 2017 3:00 PM, <[email protected]> wrote:
Today's Topics:
1. RSENSOR questions (Valerie Tan)
2. Re: RSENSOR questions ([email protected])
3. Re: RSENSOR questions (Greg Ward)
Message: 1
Date: Thu, 28 Dec 2017 12:17:49 -0500
To: [email protected]
Subject: [Radiance-general] RSENSOR questions
Message-ID:
<CAFWG2TdKo8m2nbA5qfEG-pZRJawA7uBYM9YXyFDV8REGKwLeCA@mail.gmail.com>
I am using RSENSOR on an array of "test points" for my greenhouse energy
modeling project. In general, I want to model energy arriving at different
points in the greenhouse, given weather conditions, building geometry, etc.
At each test point/sensor, I want to send backwards rays at evenly-spaced
azimuthal angles and polar angles and sum the irradiance contributions from
each ray.
I assumed that RSENSOR does what I intend to do and that my sensor file
will determine what rays are sent and in what direction. But I don't know
whether my assumption is true.
Also, I don't understand what the sensitivity values on the SPOT matrix
really mean. Overall, I just want to calculate irradiance values at each
test point by evenly sampling backwards rays in all directions.
I've looked at this:
https://www.radiance-online.org/community/workshops/2009-bos
ton-ma/Presentations/rogers_SPOT%20on.pdf
However, I don't understand the sin/cosine parts and I am focused and
radiometric units, not human-centered units like luminance.
Thank you!
Valerie
Valerie Tan
Computer Science
College of Engineering
Cornell University '19
URL: <http://www.radiance-online.org/pipermail/radiance-general/
attachments/20171228/1bf60a88/attachment-0001.html>
Message: 2
Date: Thu, 28 Dec 2017 18:24:05 +0100 (CET)
Subject: Re: [Radiance-general] RSENSOR questions
Content-Type: text/plain; charset="UTF-8"
Bonjour,
Je suis actuellement en vacances. Je serai de retour le 8 janvier 2018.
En cas d'urgence, vous pouvez toujours appeler le num?ro g?n?ral d'Estia : +41
(0) 21/510.59.59 ou envoyer un mail ? l'adresse [email protected].
Pour toutes questions relatives ? DIAL+, merci d'utiliser l'adresse mail
[email protected].
Cordialement
Julien Boutillier
Estia SA
Message: 3
Date: Thu, 28 Dec 2017 09:48:34 -0800
Hi Valerie,
If you just want irradiance at specific points, you should use rtrace with
the -I+ (capital 'i') option. Rsensor is not needed unless you have a
custom sensitivity distribution you are integrating. If you give rtrace a
list of coordinates and hemisphere (surface normal) orientations, you will
get out a list of RGB irradiance values (watts/sr/m^2):
positions.txt:
10 15 3 0 0 1
10 20 3 0 0 1
15 15 3 0 0 1
15 20 3 0 0 1
command: rtrace -h- -I+ -ab 1 scene.oct < positions.txt > results.txt
The output file will contain 3 values per line, corresponding to RGB
irradiance at each point in the order given.
The "-ab 1" option is needed to turn on interreflections. A more accurate
calculation will result from "-ab 2" or "-ab 3". You can also employ
multiple processors using the "-n" option, but be sure to add a "-af
scene.amb" option to share cached values for a more efficient calculation
if you do that.
There are many other options you may consider changing to improve the
speed/accuracy trade-off. If you have only a few points, I might suggest
something like this:
rtrace -h- -I+ -ab 3 -aa 0 -ad 4096 -lw 1e-5 -n 8 scene.oct <
The "-n 8" is appropriate for an 8-core machine, but if you only have a few
points, the calculation will take just seconds in any case.
Hope this helps!
Date: December 28, 2017 9:17:49 AM PSTHello,
each ray.
I've looked at this: https://www.radiance-online.or
g/community/workshops/2009-boston-ma/Presentations/rogers_SPOT%20on.pdf
Thank you!
Valerie
attachments/20171228/7fad29bf/attachment-0001.html>
Subject: Digest Footer
End of Radiance-general Digest, Vol 166, Issue 33
