Radiance-general Digest, Vol 136, Issue 22
Hi Axel,
I have tried to boot from UBUNTU DVD but cannot manage to install radiance yet? do you have any advices please?
Regards
Ikrima
Sent: 16 June 2015 23:01
Subject: Radiance-general Digest, Vol 136, Issue 22
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
   1. Re: Errors while transposing with Rcollate. (Greg Ward)
   2. Re: learnix installation (Axel Jacobs)
Message: 1
Date: Tue, 16 Jun 2015 12:16:08 -0700
Subject: Re: [Radiance-general] Errors while transposing with
        Rcollate.
Content-Type: text/plain; charset="windows-1252"
Well, that was quicker than expected. Just after sending this e-mail, Sarith wrote again and the problem seems to be resolved. He had an old version of rcollate that didn't work when stdin was redirected from a file, but the latest works in that mode with -t but not from a file under Windows. This was easy enough to fix, and the next NREL release should behave properly. Meanwhile, Windows folks may have to redirect the input when transposing ASCII files with rcollate.
A tempest in a teacup, really....
Subject: Re: [Radiance-general] Errors while transposing with Rcollate.
Date: June 16, 2015 11:50:02 AM PDT
Let's take this discussion offline and post again when it's resolved. At this point, it isn't clear if the problem lies with the build, the command-line interpreter or Windows system it's running under, or the rcollate command itself.
If you have some idea and want to help us work this out, write to me and I'll loop you back in.
Date: June 16, 2015 5:50:36 AM PDT
Something else that is totally bizarre is that if I type your entry on the command line, rcollate crashes with an MSVCR120.dll error, but if I paste Greg?s text into the command line it gives me the usage text ? and they appear to be completely identical commands. We are using the NREL compile of Radiance.
Rick
Sent: Tuesday, June 16, 2015 12:59 AM
Anyone else have any ideas or suggestions? Honestly, I don't know why redirecting stdin from a file would fail completely. I thought this was supported under Windows.
I'm stumped.
-G
Date: June 15, 2015 9:45:56 PM PDT
The command that you suggested returns the usage options for rcollate
in windows. (ie. Usage: rcollate [-h[io]???..)
Earlier, I had tried feeding the file to rcollate via stdin through using pipe ( | ) as well as the ?type a.txt? shell command in windows but didn?t get it work either way.
Sarith
Sent: Tuesday, June 16, 2015 12:04 AM
Hi Sarith,
This seems related to the broken handling of text versus binary files under Windows. Try reading the file from stdin, instead:
rcollate ?h ?fa1 ?t < a.txt > d.txt
If this works, let me know and I'll see if I can put in a fix.
Subject: [Radiance-general] Errors while transposing with Rcollate.
Date: June 15, 2015 5:09:13 PM PDT
Hi everyone,
I am trying to do a transpose with rcollate. My operating system is Windows. My file contains rgb triplets arranged in a (8760columns x 60rows) matrix. I either get a ?error loading file into memory? or an incorrect transpose.
I found that I got the same results with a simple ASCII file with tab separated values. My file contains:
1 2 3 4
5 6 7 8
9 10 11 12
The following commands return ?error loading file into memory?:
rcollate ?h ?fa1 ?t a.txt >d.txt
rcollate ?h ?fa1 ?ic 4 ?oc 3?t a.txt >d.txt
I found that the ?-t? flag was responsible for the error, so I tried explicitly stating the values for columns and rows as:
rcollate ?h ?fa1 ?ic 4 ?ir 3 ?oc 3 ?ir 4 a.txt>d.txt
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Am I missing something?
Sarith
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150616/846a1090/attachment-0001.html&gt;
Message: 2
Date: Tue, 16 Jun 2015 23:00:51 +0100
Subject: Re: [Radiance-general] learnix installation
Content-Type: text/plain; charset=windows-1252; format=flowed
Hi Ikrima,
I'm afraid LEARNIX is no longer maintained. You can still download the ISO image from here: http://www.jaloxa.eu/mirrors/learnix/index.shtml
but be aware that the latest release is from 2011.
Chances are that if you run it on hardware later than 2011, you will get problems, which are most likely to show up with weird display issues, or networking hardware not working.
To add insult to injury, the copy of Radiance that comes with this old LEARNIX CD-ROM is from, well... 2011.
You are much better off trying out a bootable UBUNTU CD-ROM or DVD. If you read the 'Running LEARNIX' PDF, available under 'Documentation', you'll find a number of different ways of running LINUX alongside or within Windows.
Installing Radiance from the standard Debian or Ubuntu repositories is fairly straight-forward.
Hope you will succeed with you endeavour.
Best
Axel
On 16/06/15 17:32, Ikrima Amaireh wrote:
Hi All,
How can I get learnix copy? And is learnix much different/better than knoppix itself for running radiance?
Regards
ikrima
[mailto:[email protected]]
Sent: 16 June 2015 14:50
Subject: Radiance-general Digest, Vol 136, Issue 19
Today's Topics:
    2. Re: Errors while transposing with Rcollate.
       (David Geisler-Moroder)
Message: 1
Date: Mon, 15 Jun 2015 21:58:40 -0700
      Rcollate.
I'm stumped.
-G
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
-------------- next part -------------- An HTML attachment was
scrubbed...
URL:
/20150615/b9ed1f79/attachment-0001.html>
Message: 2
Date: Tue, 16 Jun 2015 15:50:19 +0200
      Rcollate.
Message-ID:
      <CAL-bo5Gfz3PRp=qPWFVVagLXZiqKU_-7S6t4Xkr4nj_CYfO8aQ@mail.gmail.com>
Hi Sarith,
I just tried both calls (with and w/o redirecting from stdin) with the
latest Windows binaries from
NREL(https://github.com/NREL/Radiance/releases\)
and both work fine at my side...
rcollate ?h ?fa1 ?t a.txt > d.txt
Which version of rcollate are you using?
David
2015-06-16 6:58 GMT+02:00 Greg Ward <[email protected]>:
I'm stumped.
-G
*Subject: *Re: [Radiance-general] Errors while transposing with Rcollate.
*Date: *June 15, 2015 9:45:56 PM PDT
Sarith
*Sent:* Tuesday, June 16, 2015 12:04 AM
*Subject:* Re: [Radiance-general] Errors while transposing with Rcollate.
Hi Sarith,
*Subject: *[Radiance-general] Errors while transposing with Rcollate.
*Date: *June 15, 2015 5:09:13 PM PDT
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
*rcollate ?h ?fa1 ?t a.txt >d.txt*
*rcollate ?h ?fa1 ?ic 4 ?oc 3?t a.txt >d.txt*
*rcollate ?h ?fa1 ?ic 4 ?ir 3 ?oc 3 ?ir 4 a.txt>d.txt*
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Dipl.-Ing. Dr. David Geisler-Moroder
Hofwaldweg 14/20
6020 Innsbruck
Austria
scrubbed...
URL:
/20150616/9e09e6b0/attachment.html>
End of Radiance-general Digest, Vol 136, Issue 19
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete it.
Please do not use, copy or disclose the information contained in this
message or in any attachment. Any views or opinions expressed by the
author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
attachment may still contain software viruses which could damage your
computer system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
End of Radiance-general Digest, Vol 136, Issue 22
