Radiance-general Digest, Vol 135, Issue 16
Hi Zack,
Many thanks for your advices.
Regarding SPOT Pro, it seems that it can work out annual simulation for CFS with BSDF but for grid points we still need to use command-line (as you clarified). Also, we still need to use command-line (radiance) to generate BSDF that will be used with SPOT Pro . Is that right?
Also, what is the difference between SPOT Pro and Daysim tools in terms of accuracy and flexibility (as both using Radiance engine)?
Regards
Ikrima
Sent: 13 May 2015 15:26
Subject: Radiance-general Digest, Vol 135, Issue 16
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
   1. Re: Rendering using Radiance_As Beginners - SPOT Pro released
      (Zack Rogers)
   2. Fwd: rcontrib for rendering - missing required modifier
      argument ([email protected])
   3. Re: Fwd: rcontrib for rendering - missing required modifier
      argument (Christopher Rush)
Message: 1
Date: Tue, 12 May 2015 21:45:42 -0600
Subject: Re: [Radiance-general] Rendering using Radiance_As Beginners
  - SPOT Pro released
Message-ID:
  <CAAP856zvGniQ_jtBztN7O5jOy12bvp5O+_Fy67zvjRp2cb=RgA@mail.gmail.com>
Hi Ikrima,
One Windows-based user interface that might fit your needs is the Sensor Placement + Optimization Tool (SPOT) <http://www.daylightinginnovations.com/spot-home&gt;
daylighting software. A new version, SPOT Pro, was just released and is now available for download at the above website.
SPOT Pro provides an interface to Radiance and has the capability to perform annual daylighting simulation using BSDF files to describe Complex Fenestration Systems (CFS) and allowing you to schedule automated and/or manual control of the window treatments. The SPOT interface allows you to build simpler orthogonal geometry, assign materials and render or simulate throughout the year. Importing from sketchup can be done behind the scenes and will be available soon. SPOT also allows for further analysis and optimization and photosensor systems in your daylit space if desired.
Calculation of vertical illuminance grids, or other directional illuminance points, if needed, are not built into the program but can certainly be calculated behind the scenes of a SPOT model without too much command line interface.
The software is in a final Beta testing stage where we are testing downloads, installation and operation on different machine types, operating systems, and MS Office versions. If the trial version downloads, installs, and starts up on your machine - chances are you are good to go. If not, please report issues to [email protected].
Good timing for your questions - SPOT Pro was just posted and I was just about to send out such an announcement to the list.
Zack
On Tue, May 12, 2015 at 8:40 AM, Ikrima Amaireh <[email protected]> wrote:
I just started using Radiance and it seems to me difficult so I need
your advices please.
1. As Radiance Desktop is no more recommended for CFS daylighting,
what is the alternative if one wants to study illuminance distribution
(points values) inside an office that has CFS (with both diffuse and
specular materials)?
2. Is there any user-friendly-interface program that can do the
task without the need to work with command-line procedure (that I am
not good with at all)?
3. If it?s compulsory to use command-line tools, how can we
construct/import CAD geometry and assign its materials?
4. And, is there a step-by-step tutorials on how to run Radiance
(in case of command-line)?
Your help/advice is really so appreciated.
Many thanks in Advance J
Ikrima Amaireh
University of Nottingham, UK
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete it.
Please do not use, copy or disclose the information contained in this
message or in any attachment. Any views or opinions expressed by the
author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
attachment may still contain software viruses which could damage your
computer system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
Zack Rogers, P.E., LEED AP BD+C
Daylighting Innovations, LLC
808 S. Public Road, Suite 200
Lafayette, CO 80026
(303)946-2310
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150512/3ce4df00/attachment-0001.html&gt;
Message: 2
Date: Wed, 13 May 2015 11:00:53 +0200
Subject: [Radiance-general] Fwd: rcontrib for rendering - missing
  required modifier argument
Message-ID:
  <[email protected]>
Content-Type: text/plain; charset="utf-8"; Format="flowed";
  DelSp="Yes"
I tried following your indications and it worked, although, I had to remove
Nkbins because it is undefined variable. I do not way but it could be not
having??such as the Tregenza skydiscretization...
I removed and thus, the default number is 0:
  C:\Radiance\test>vwrays -ff -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0 -1 0
-x 600
  -y 600 | rcontrib -x 600 -y 392 -ld- -ffc -fo -o vmx/window_%03d.hdr -f
klems_an
  g.cal -b kbinS -bn Nkbins -m windowglow -ab 12 -ad 50000 -lw 2e-5
model_vmx.oct
  rcontrib: Nkbins`RC: undefined variable
   C:\Radiance\test\20150505>vwrays -ff -vtv -vh 94 -vv 70 -vp 1.5 5 1.75
-vd 0 -1
   0 -x 600 -y 600 | rcontrib -x 600 -y 392 -ld -ffc -fo -o
vmx/window_%03d.hdr -m
   windowglow -ab 12 -ad 50000 -lw 2e-5 model_vmx.oct
However, generated window_000.hdr file does not have light. It is a black
image, even though,?the render generated by rvu of the room it is ok.
Do you know why does it happen?
Thank you!
Kind regards,
Urtza
----- Mensaje reenviado de [email protected] -----
Fecha: Thu, 07 May 2015 19:35:42 +0200
? ? De: [email protected]
Asunto: Re: [Radiance-general] rcontrib for rendering - missing required
modifier argument
? Para: Radiance general discussion <[email protected]>
Thank you very much!
I will try to follow your indications.
Best wishes,
Urtza.
Greg Ward <[email protected]> escribi?:
Hi Urtza,
The problem is the use of double-quotes for? "vwrays -vtv -vh 94 -vv 70
-vp 1.5 5 1.75 -vd 0 -1 0 -x 600 -y 600 -d", which used singe back-quotes
under Unix.? This replaces the command with its output on the command
line, something Windows does not do.? Substituting with double-quotes is
the wrong thing to do.? Instead, execute this command yourself, then cut
and paste the output into the rcontrib command line in its place.
The output is "-x 600 -y 392 -ld-", so you would use:
? ? ? ? vwrays -ff -vf -vtv -vh 94 -vv 70 -vp 1.5 5 1.75 -vd 0-1 0 -x
600 -y 600 | rcontrib -x 600 -y 392 -ld- -ffc -fo -o vmx/window_%03d.hdr -f
klems_ang.cal -b kbinS -bn Nkbins -m windowglow -ab 2 12 -ad 50000 -lw 2e-5
model_vmx.oct
As the actual command in Windows.
Subject: Re: [Radiance-general] rcontrib for rendering - missing required
modifier argument
Date: May 7, 2015 12:19:37 AM PDT
Hello Greg,
This is the command line:
C:\Radiance\test\20150505>vwrays -ff -vf -vtv -vh 94 -vv 70 -vp 1.5 5
1.75 -vd 0
-1 0 -x 600 -y 600 | rcontrib "vwrays -vtv -vh 94 -vv 70 -vp 1.5 5 1.75
-vd 0 -
1 0 -x 600 -y 600 -d" -ffc -fo -o vmx/window_%03d.hdr -f klems_ang.cal -b
kbinS
-bn Nkbins -m windowglow -ab 2 12 -ad 50000 -lw 2e-5 model_vmx.oct
-vtv: no view in file
rcontrib: fatal - missing required modifier argument
I attach you the window.rad file (material + geometry)
Urtza.
Can you show us the command line that reports an error, exactly as you
are giving it?? (Cut and paste if you can.)
Subject: [Radiance-general] rcontrib for rendering - missing required
modifier argument
Date: May 6, 2015 2:38:37 AM PDT
I have problems with rcontrib program with Windows 8 SO. I am trying to
do Example 1 of A McNeil The Three-Phase Method. I would like to render
with vwrays with a windowglow in a test room. However, missing required
modifier argument message script. Does anyone know what is the problem with
the modifier?
Thank you in advance,
Kind regards,
Urtza.
----- Terminar mensaje reenviado -----
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150513/520c8aa5/attachment-0001.html&gt;
Message: 3
Date: Wed, 13 May 2015 14:25:14 +0000
Subject: Re: [Radiance-general] Fwd: rcontrib for rendering - missing
Message-ID:
  <88079A360FAC7441AE93ECBF61998236273D0E61@AMXExMb02.global.arup.com>
What do you use to view the HDR image? Try typing:
ximage -e auto window_000.hdr
This will automatically adjust the exposure of your image upon initially opening the file. It could be that your image does have non-zero values but the exposure is skewed in your viewpoint making it look black with the default exposure value.
Or type
ximage window_000.hdr
then hit the ?a? key while ximage is active to view it with automatic exposure
while ximage is active you can also hit the ?=? key and click a point in the image to adjust the exposure according to various points in the image
Sent: Wednesday, May 13, 2015 5:01 AM
However, generated window_000.hdr file does not have light. It is a black image, even though, the render generated by rvu of the room it is ok.
Thank you!
Kind regards,
Urtza
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150513/0dda6020/attachment.html&gt;
End of Radiance-general Digest, Vol 135, Issue 16
