Radiance-general Digest, Vol 132, Issue 12
Hi Mostapha,
Thank you - helpful! Where is this behaviour documented? I could not find it in the rfluxmtx or rcontrib manpages.
Reinier Zeldenrust
Environmental Designer
Atelier Ten
Environmental Design Consultants + Building Services Engineers
CIBSE Building Services Consultancy of the Year 2011
UK-GBC Sustainability Consultant of the Year 2009
Sent: 20 February 2015 20:00
Subject: Radiance-general Digest, Vol 132, Issue 12
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
   1. Three-phase method troubles: NROWS missing after rfluxmtx
      (Reinier Zeldenrust)
   2. Re: Three-phase method troubles: NROWS missing after rfluxmtx
      (Mostapha Sadeghipour)
Message: 1
Date: Fri, 20 Feb 2015 11:59:55 +0000
To: "[email protected]"
  <[email protected]>
Subject: [Radiance-general] Three-phase method troubles: NROWS missing
  after rfluxmtx
Message-ID:
  <DB4PR05MB06886147C3E2FADF949EFE8FF42A0@DB4PR05MB0688.eurprd05.prod.outlook.com>
I am following the latest approach to the three-phase method as described in Andy McNeil's 2014 Radiance Workshop Presentation, but when I generate view matrices my output is botched.
With this command (I realise this is low accuracy, but for the moment I'm mainly testing workflow) :
  rfluxmtx -ab 4 -ad 5000 < ChEast.pts - windows_pts/window_00.rad material.rad ChEast.rad > viewpts_00.mtx the header in the viewmatrix is as follows:
  #?RADIANCE
  oconv -f material.rad ChEast.rad windows_pts/window_01.rad
  rcontrib -fo+ -ab 4 -ad 5000 -faa -c 1 -f klems_full.cal -bn Nkbins -b kbin(0.525501,0.0136168,-0.850684,0,0,1) -m M-nor
  SOFTWARE= RADIANCE 4.3a lastmod by nrel_nt
  gugliel on rgugliel-W7-VM
  CAPDATE= 2015:02:19 12:21:14
  GMT= 2015:02:19 12:21:14
  NCOMP=3
  NCOLS=145
  FORMAT=ascii
When I try to do any matrix multiplication to get the three-phase result, I get problems with RMTXOP or dctimestep, which complain they can't load the matrix. If I add the line NROWS=81 (number of sensor points) manually in the header, I do get results. But I'm trying to run the simulation for a lot of windows so adding this line each time manually or with a script is a bit painful. Am I doing something wrong or is this a bug?
Additionally, when I try to run dctimestep in annual mode, using the following command:
  dctimestep -n 8760 viewpts_00.mtx grate.xml daylight_00.mtx annual.smx > test.dat I get:
  'fatal - unexpected EOF reading annual.smx'
even though my annual.smx has 146 rows (for all 146 Tregenza daylight patches) and 8760 columns.
Any idea what is going wrong here?
Many thanks,
Reinier
Reinier Zeldenrust
Atelier Ten
Message: 2
Date: Fri, 20 Feb 2015 09:48:26 -0500
Subject: Re: [Radiance-general] Three-phase method troubles: NROWS
Message-ID:
  <CAAd_PgQwa7dC_5zHHBC2FZ4S2c83NUY5YyLD9ea=CoNDoubrZg@mail.gmail.com>
Hi Reinier,
You need to use the -y option to specify the number of rows in your rfluxmtx run so you don't need to do it manually.
Mostapha
On Fri, Feb 20, 2015 at 6:59 AM, Reinier Zeldenrust < [email protected]> wrote:
        #?RADIANCE
        NCOMP=3
        NCOLS=145
        FORMAT=ascii
following command:
Many thanks,
Reinier
Reinier Zeldenrust
Atelier Ten
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150220/e5d551db/attachment-0001.html&gt;
End of Radiance-general Digest, Vol 132, Issue 12
Hi Reinier,
I don't think it is documented yet (or is it?). I had the same issue while
ago and Greg helped me to get it solved so that's why I knew.
You may also find Rob's implementation of 3Phase to OpenStudio helpful:
Mostapha
On Mon, Feb 23, 2015 at 12:59 PM, Reinier Zeldenrust < [email protected]> wrote:
Hi Mostapha,
Reinier Zeldenrust
Atelier Ten
[email protected]]
Today's Topics:
Message: 1
        <[email protected]>
        after rfluxmtx
Message-ID:
follows:
        #?RADIANCE
        NCOMP=3
        NCOLS=145
        FORMAT=ascii
following command:
Many thanks,
Reinier
Reinier Zeldenrust
Atelier Ten
Message: 2
Message-ID:
[email protected]>
Hi Reinier,
Mostapha
On Fri, Feb 20, 2015 at 6:59 AM, Reinier Zeldenrust < > [email protected]> wrote:
> Hi all,
> #?RADIANCE
> NCOMP=3
> NCOLS=145
> FORMAT=ascii
or is this a bug?
> following command:
> Many thanks,
> Reinier
> Reinier Zeldenrust
> Atelier Ten
> [email protected]
URL: <
Hi Reiner,
It's true that this behavior is not properly documented. If you can suggest a logical place where you would expect to find it, perhaps I can add the appropriate text.
Since rfluxmtx and rmtxop are new, the documentation is not as complete as it should be.
Subject: Re: [Radiance-general] Radiance-general Digest, Vol 132, Issue 12
Date: February 23, 2015 9:59:29 AM PST
Hi Mostapha,
Reinier Zeldenrust
Atelier Ten
Message: 1
  <[email protected]>
  #?RADIANCE
  NCOMP=3
  NCOLS=145
  FORMAT=ascii
Many thanks,
Reinier
Reinier Zeldenrust
Atelier Ten
Message: 2
Hi Reinier,
Mostapha
Thanks, Mostapha! We get the number of points from the input file (created by the OpenStudio-to-Radiance model translator), here:
https://github.com/NREL/OpenStudio/blob/develop/openstudiocore/ruby/openstudio/radiance/DaylightSim-Simple.rb#L375-377
...then pass that to the -y option to rfluxmtx here:
https://github.com/NREL/OpenStudio/blob/develop/openstudiocore/ruby/openstudio/radiance/DaylightSim-Simple.rb#L433
BTW this was all merged to the main develop branch just last week; we are testing it and documenting it now and this whole 3-phase/shade control thing will be included in OpenStudio v1.7.0 next month, and it'll be in the next iteration release for bleeding edge types, next week. =)
On 2/23/15, 11:18 AM, "Mostapha Sadeghipour" <[email protected]<mailto:[email protected]>> wrote:
Hi Greg, et. al,
Is there any chance that you can also add some notes about the headings.
There are couple of them in Andy's presentation for .rad or sky files (e.g
#@rfluxmtx h=kf u=+Y or #@rfluxmtx h=u u=Y). I wonder what are other
options available.
Mostapha
PS: Congrats Rob! Can't wait to see it flying in the wild! :slight_smile:
On Mon, Feb 23, 2015 at 1:52 PM, Guglielmetti, Robert < [email protected]> wrote:
On 2/23/15, 11:18 AM, "Mostapha Sadeghipour" <[email protected] > <mailto:[email protected]>> wrote:
I found the answer to my question here: (
http://www.radiance-online.org/learning/documentation/manual-pages/pdfs/rfluxmtx.pdf/view\)
Sorry and thank you!
-Mostapha
On Mon, Feb 23, 2015 at 2:08 PM, Mostapha Sadeghipour <[email protected] > wrote:
Hi Greg, et. al,
options available.
Mostapha
On Mon, Feb 23, 2015 at 1:52 PM, Guglielmetti, Robert < > [email protected]> wrote:
On 2/23/15, 11:18 AM, "Mostapha Sadeghipour" <[email protected] >> <mailto:[email protected]>> wrote:
