Thanks for the prompt responses. I will respond to both in sequence.
Ross
Message 1
Hi John,
'oconv materials.rad test.rad > test.oct'
still produces the error message 'xform: cannot find file...'
I have added a screenshot (error1) to the folder below:
https://www.dropbox.com/sh/uyokuvxiu9s1ifb/AAB5TXbez6p8-FAgl3EeR4f2a
With regards to 'objview' I don't actually have that program.
I downloaded a windows version of radiance from the link below and it wasn't included.
https://openstudio.nrel.gov/getting-started-developer/getting-started-radiance
Message 2
Hi Thomas
'rad test.rif' runs and produces and HDR file but it is completely black.
'xform test.rad > test_combined.rad' again gives an error that it can't find the file 'test.rad' which is clearly at the location.
I have put a screenshot of the error into the my dropbox folder (error2)
The huge number of materials was because I had previously imported some DAYSIM results. These have now been purged off an the export files updated.
Message: 1
Date: Tue, 17 Jun 2014 09:04:01 +0000
To: "[email protected]"
<[email protected]>
Subject: Re: [Radiance-general] Create Octree File from SU2RAD
Hi Ross,
You need to include the materials file in the oconv command, and have it before the geometry. Try:
or, to view the scene 'on the fly':
objview materials.rad test.rad
Cheers
John
John Mardaljevic PhD FSLL
Professor of Building Daylight Modelling School of Civil & Building Engineering Loughborough University Loughborough Leicestershire
LE11 3TU, UK
Tel: +44 1509 222630 (Direct)
Personal daylighting website:
http://climate-based-daylighting.com
Message: 2
Date: Tue, 17 Jun 2014 08:11:14 -0500
Message-ID:
<CAKGV-k3c6CM_Q3sg0YM1ef9zxLq2rV5_3goPoE6uJeQfxckZFQ@mail.gmail.com>
Ross
For a beginner it's usually easier to use the rad command with the *.rif file to get scenes rendered.
$ rad test.rif
That will start rendering all scenes and create the images - in your case only one.
However, looking at the *.rif file I see that there is a warning at the end:
## total number of objects too large
Unfortunately I don't remember why I put this message there. There may be a built-in limit for oconv or another process in Radiance. What happens if you combine all the output files to a single file with the xform command?
If this works you can run oconv with the test_combined.rad file:
oconv test_combined.rad > test.oct
BTW: Is there a specific reason to have so many materials in your scene?
Most of your scene files contain only a few polygons. You can also try to export the scene by group or by layer in su2rad. That (probably) reduces the file count and can solve your problem.
On Tue, Jun 17, 2014 at 2:44 AM, Thompson, Ross <[email protected]> wrote:
I am now looking to use radiance after learning daysim. I have
successfully completed the tutorial and am now looking to produce
renders from scenes set up in SketchUp.Here is a link to the SketchUp output file:
Dropbox - Error - Simplify your life
My approach is to apply the OCONV function to the ?test.rad? file.
However unlike in the tutorial, materials and geometry are housed in
separate directories.And I get the following errors:
oconv test.rad > test.oct
xform: cannot find file "objects/Material133.rad"
oconv: warning - (!xform objects/Material133.rad): empty file
I don?t quite understand why the file can?t be found.
Am I using the correct approach?
Thanks in advance for your help.
Ross
Ross Thompson
Senior Sustainability & Energy Engineer
T: 01865 864500
*Oxford:*
South House
3 Farmoor Court
Cumnor Road
Oxford OX2 9LU
*Phone*: 01865 864500
*Fax*: 01865 864584
*Email*: [email protected]*London:*
Lector Court
151-153 Farringdon Road
London EC1R 3AF
*Phone*: 0207 833 8815
*Fax*: 0203 302 0050
*Email*: [email protected]*For the latest CBG news visit **www.cbgc.com* <http://www.cbgc.com>
[image: CBGConsultantsltd Facebook]
<http://facebook.com/cbgconsultantsltd> [image: CBG Consultants
Twitter] <x.com;CBG Consultants Ltd Registered No. 538 4147/VAT Registration No. 860
3120
63*Please consider the environment - do you really need to print this
email?*The views expressed in this e-mail are those of the sender and not
necessarily those of CBG Consultants.The content of this email is private and may be confidential for the
intended recipient only. If misdirected, please notify us by telephone
and confirm that it has been deleted from your system and any copies destroyed.
If you are not the intended recipient you are strictly prohibited from
using, printing, copying, distributing or disseminating this e-mail or
any information contained in it.We use reasonable endeavours to virus scan all e-mails leaving the
company but no warranty is given that this e-mail and any attachments
are virus free. You should undertake your own virus checking. The
right to monitor e-mail communications through our networks is reserved by us.
We are proud to announce that CBG Consultants have been shortlisted for the CIBSE Building Services Consultancy of the year (up to 100 employees) Award 2014.
Oxford:
South House,
3 Farmoor Court,
Cumnor Road,
Oxford OX2 9LU
T: 01865 864500
F: 01865 864584
E: [email protected]
London:
Lector Court,
151-153 Farringdon Road,
London EC1R 3AF
T: 0207 833 8815
F: 0203 302 0050
For the latest CBG news visit www.cbgc.com
CBG Consultants Ltd Registered No. 538 4147/VAT Registration No. 860 3120 63
Please consider the environment - do you really need to print this email?
The views expressed in this e-mail are those of the sender and not necessarily those of CBG Consultants.
The content of this email is private and may be confidential for the intended recipient only. If misdirected, please notify us by telephone and confirm that it has been deleted from your system and any copies destroyed. If you are not the intended recipient you are strictly prohibited from using, printing, copying, distributing or disseminating this e-mail or any information contained in it.
We use reasonable endeavours to virus scan all e-mails leaving the company but no warranty is given that this e-mail and any attachments are virus free. You should undertake your own virus checking. The right to monitor e-mail communications through our networks is reserved by us.
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20140617/23bbcec0/attachment.html>
Type: image/png
Desc: not available
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20140617/23bbcec0/attachment.png>
Type: image/png
Desc: not available
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20140617/23bbcec0/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20140617/23bbcec0/attachment-0002.png>
End of Radiance-general Digest, Vol 124, Issue 12
