Radiance Ecotect 2011 and Ecote'ct v5
Hi everyone,
Does anyone have some troubles with Ecotect 2011 and Radiance for dayllight Factor Calculation?
When i compare the dyalight factor using Ecotect v5 with radiance or Ecotect 2011 with Radiance as well, the results are completly different. Even when i'm only using Ecotect to calculate the Daylight Factor.
Alexis
Date: Fri, 19 Nov 2010 15:49:22 -0500
Subject: Re: [Radiance-general] Request for training workshop on Radiance linux
Vidya.
You can download the "Radiance Tutorial" by Axel Jacobs here:
http://luminance.londonmet.ac.uk/learnix/docs.shtml
There are also a few other documents but the tutorial is a very
good start especially with regard to the command line.
On Fri, Nov 19, 2010 at 3:16 PM, vidya gowda <[email protected]> wrote:
> Dear Radiance Users,
> I am a PhD student focusing on daylight studies and would like to use
> radiance linux for my research. We have a windows 7 and the linux version of
> radiance is accessed virtually. I am getting stuck with using the software,
> and operating with the command lines, and would greatly appreciate if anyone
> could suggest a workshop or online training sessions or some basics. Sorry
> for such beginner questions but can I also know what language and supporting
> software should I work with to be able to write the commands.
> Thanks in advance,
> Kind regards,
> Vidya Gowda,
> [email protected]
> Radiance-general mailing list
> [email protected]
> http://www.radiance-online.org/mailman/listinfo/radiance-general
Dear Alexis,
Yes, the results are different and Diego and I would argue that
Ecotect-Split-Flux is wrong
(http://www.gsd.harvard.edu/research/gsdsquare/Publications/BuildingSimu
lation2009.SimulationNovices.pdf).
Christoph
[mailto:[email protected]] On Behalf Of
alexis Loubeyre
Sent: Monday, November 22, 2010 8:57 AM
Subject: RE: [Radiance-general] Radiance Ecotect 2011 and Ecote'ct v5
Hi everyone,
Alexis
Radiance linux
Vidya.
use
version of
software,
if anyone
Sorry
supporting
> Thanks in advance,
> Kind regards,
> Vidya Gowda,
> [email protected]
> [email protected]
Hi Alexis,
Ecotect uses an entirely different method for calculating daylight factors than Radiance. If I recall correctly, it uses a split flux method with relatively coarse sampling. So at best this might be useful for a very very simple room (and perhaps even then for an initial approximation). Radiance on the other hand uses much more sophisticated methods and is capable of dealing with very complicated geometry. Christoph Reinhart at Harvard has done some work on this.
# Jack de Valpine
On 11/22/2010 8:56 AM, alexis Loubeyre wrote:
Hi everyone,
Alexis
> From: [email protected]
> Vidya.
> Regards,
> Thomas
> > Thanks in advance,
> > Kind regards,
> > Vidya Gowda,
> > [email protected]
> > [email protected]
> [email protected]
