Hi Philip,
Your post was blocked because it is too big. I've released a couple of others and increased the post size limit to 60K, but this is well over that. We have a limit so as not to clog people's in boxes.
Anyway, the instructions for removing X11 are out of date. In your case, you can just take the "rvu" target out of the src/rt/Rmakefile, because you won't need it if you aren't doing interactive rendering on your nodes. I have cleaned up the process for future.
P.S. I'm going to go ahead and reject this post, but I am copying my reply sans attachment to radiance-dev so others can see.
Subject: Re: [Radiance-dev] how serious are these remaining 5 build errors?
Date: April 6, 2018 10:39:18 AM PDT
To: code development <[email protected]>Hello Greg,
thanks a lot for that (so glad you sent it just before my weekend!)
I think that resolves all issues (hopefully I still think the same on Monday
Regarding noX11.help, FWIW, I did have a go at closely following the instructions but I found that they didn't result in the X11-related compilation errors being eliminated. It's not impossible that I made a mistake, but FWIW there also seemed to be a discrepancy between Radiance/noX11.help at 5.0 · NREL/Radiance · GitHub and what I found I had to change in rt/devtable.c:
Thanks and have a great weekend.
Philip
On 6 April 2018 at 17:10, Gregory J. Ward <[email protected]> wrote:
The newer libtiff you installed probably doesn't have a "distclean" target. The one I typically use, which IS included in the rad5R1supp.tar.gz file you look under ray/src/px/tiff, does have this target. In any case, the error just means that directory didn't get cleaned of its object files. It has no bearing on the resulting compilation, just the size of the leftovers if you do a final "makeall clean" after installing the binaries.The rest of the output from your build looks like warnings you can ignore. Compilers like to add warnings about things they don't understand every year, and I simply can't (or don't bother) keeping up with these.
Regarding X11 removal, the top-level directory (ray/) has a file called "noX11.help" that explains the changes to make to the Rmakefile's if you don't have X11 on your system.
Finally, you don't absolutely need *anything* in the ray/lib directory from rad5R1supp.tar.gz. In fact, you don't need anything from this overlay at all, other than the tiff directory if you want to have tiff conversion. All of the auxiliary files that are required to run Radiance are included in the ray/src/* directories and installed in the ray/lib directory during build.
I hope this helps. (Just woke up a bit ago here in California.)
Date: April 6, 2018 3:46:14 AM PDTHello,
I am seeing the following error again, even after adding the src/px/tiff directory:
build-#1-console-output.txt · GitHub
This is how it looks now:
cd tiff; make distclean
make[1]: Entering directory `/home/radiance/src/px/tiff'
make[1]: *** No rule to make target `distclean'. Stop.
make[1]: Leaving directory `/home/radiance/src/px/tiff'
make: *** [clean] Error 2Should I ignore the error? Is there a way to eliminate it?
Philip Schwarz
On 5 April 2018 at 19:43, Philip Schwarz <[email protected]> wrote:
@GregYes, I can confirm that if I download the Radiance overlay (Auxiliary files) and take the src/px/tiff directory, and add it to the radiance 5.0 codebase that I am trying to build, the following errors go away:
make clean error
build-#1-console-output.txt · GitHubLib tiff error
build-#1-console-output.txt · GitHubmake: Target `install' not remade because of errors.
build-#1-console-output.txt · GitHubThat leaves me with the following:
Cannot find wish executable in current path -- trad not installed.
build-#1-console-output.txt · GitHubThere were some errors.
build-#1-console-output.txt · GitHubYou have explained why the first is happening, and the second is just a message which would not appear if the first error wasn't there.
Thanks for that. Great.
The Radiance overlay (Auxiliary files) are 380MB (unzipped) - the src/px/tiff directory within them is 8-9MB.
As you pointed out in another email, I am using a very stripped down version of Linux. amazonlinux 2017.09 is 165MB.
We want it to be as small as possible to keep down the cost and time it takes to create deploy and run our application in a docker container on AWS.Right now, we are going to start off wanting to run just oconv and rtrace. In time, we may run more commands.
On that basis, adding all of the Radiance overlay to our application seems prohibitive.
Is there something that conveys how Radiance's various binaries rely on which part of the Radiance overlay?
E.g. you said that if we can do without ra_tiff then we don't need src/px/tiff - by the way, what is ra_tiff? I don't think I can see it among the binaries created by the build.
Can oconv and rtrace run without ra_tiff?
Does the idea of running without the Radiance overlay make any sense, e.g. if wanting to run just oconv and rtrace?
What is the set of binaries that can happily run without Radiance overlay? Are oconv and rtrace among them? If not, what portions of the Radiance overlay do they rely on?
Is it possible to pick and choose, within reason, which parts of the Radiance overlay are needed based on the binaries one wishes to run?Any help would be greatly appreciated.
Philip
On 5 April 2018 at 18:01, Gregory J. Ward <[email protected]> wrote:
After installing "ed", you would need to remove the unedited Version.c file to recreate it with makeall.Regarding your other errors, you need to install the Radiance overlay (Auxiliary files) that includes the src/px/tiff directory (I think). The link was on the downloads page:
This is also responsible for the distclean error. You can just ignore the errors related to libtiff and do without ra_tiff in your distro.
To run trad, you need to install wish. If you don't have it, you can't use that program, so it doesn't bother installing.
Date: April 5, 2018 9:19:57 AM PDTHello,
now that I no longer get X11-related compilation errors, I am down to the following 5:
make clean error
build-#1-console-output.txt · GitHubCannot find wish executable in current path -- trad not installed.
build-#1-console-output.txt · GitHubI would really appreciate it if you could have a quick look.
Is there a quick fix for them?
If not, how serious are they?
Thank you for your help.
Philip
