Radiance-daysim Digest, Vol 26, Issue 4
Thanks again. I have changed the output_units from 2 to 1 in my file*.hea
and saved it. But Daysim still considering illuminance sensors. How could I
reload my file*.hea in order to Daysim can consider irradiance sensors?
Besides, I have changed the sensor_file_unit from 0 to 2, but Daysim still
Many thanks
On Thu, Aug 11, 2016 at 9:00 PM, < [email protected]> wrote:
Send Radiance-daysim mailing list submissions to
than "Re: Contents of Radiance-daysim digest..."
Today's Topics:
   1. Re: Radiance-daysim Digest, Vol 26, Issue 2 (Christoph Reinhart)
   2. Re: Radiance-daysim Digest, Vol 26, Issue 3 (Abigail Chi)
Message: 1
Date: Thu, 11 Aug 2016 12:26:05 +0000
To: DAYSIM discussion <[email protected]>
Subject: Re: [Radiance-daysim] Radiance-daysim Digest, Vol 26, Issue 2
Message-ID:
        <1B23446CBF250648A2FC775DE3FE7E80FF463DA1@OC11expo28.
exchange.mit.edu>
-I haven't used the new version of DIVA yet, so maybe someone else can
answer this question more detailed. I know you can go two approaches,
either you define a node in W/m*m and run an annual simulation with daysim
OR you run an irradiation map with gencumulativesky ,but I'm not sure
where to invoke the latter one in the new version.
In Rhino go to Metrics >>Daylight Grid-Based >> Daysim-Based hourly Method
URL: <http://www.radiance-online.org/pipermail/radiance-daysim/
attachments/20160811/a95e46a8/attachment-0001.html>
Message: 2
Date: Thu, 11 Aug 2016 14:30:13 +0200
Subject: Re: [Radiance-daysim] Radiance-daysim Digest, Vol 26, Issue 3
Message-ID:
        <CAPSjnYiYWUBC2uO_N4sXOvCTmRV8q4hrrmDKjSrZhC3xrN
[email protected]>
Many thanks
> Message: 2
> Date: Thu, 11 Aug 2016 13:06:46 +0200
> From: Jan Wienold <[email protected]>
> Message-ID: <[email protected]>
> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
> Hi Abigail,
> -for the solar transmissivity you can use the same equation.
> -the pts-file does not contain the information about the sensor type. If
> you want to change that manually, you have to do that in the header
> file. Syntax please see here:
> http://daysim.ning.com/page/keyword-output-units . If you have hundreds
> of points, I recommend to write a script generating for you this entry
> in the header-file.
> daysim OR you run an irradiation map with /gencumulativesky /,but I'm
> not sure where to invoke the latter one in the new version.
> good luck!
> Jan/
> On 11/08/16 12:09, Abigail Chi wrote:
> > Hi Jan
> > To compute trasnmissivity (tn) from transmittance (Tn), I should use:
> > tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.
> 0036261119/Tn
> > But, how can I compute the solar transmissivity from the solar
> > transmittance?
> > Besides, can you help me with the following:
> > - What is the way in Daysim to customize all sensor points in the
> > file *.pts as irradiance sensors? This last in order to avoid
> > customizing all sensors, one by one, in the sensor type column of the
> > Daysim interface.
> > - I am new in Diva-for-Rhino, but I have seen that it can
> > calculate annual irradiation at node locations (radiation maps-grid
> > based). Is this equivalent to the calculation of the solar irradiation
> > in Daysim?
> > Many thanks
attachments/20160811/e27bb27c/attachment-0001.html>
End of Radiance-daysim Digest, Vol 26, Issue 4
I am coping snipets form a owrkng header file below.
# site information
place Minneapolis St Paul IntL Arp_USA
latitude 44.88
longitude 93.23
time_zone 90
site_elevation 254.0
first_weekday 1
time_step 60
wea_data_short_file USA_MN_Minneapolis-St.Paul.wea
wea_data_short_file_units 1
lower_direct_threshold 2
lower_diffuse_threshold 2
output_units 2
sensor_file_info 0 0 0 0
sensor_file_unit 2 2 2 2
Sent: Friday, August 12, 2016 6:54 AM
Subject: Re: [Radiance-daysim] Radiance-daysim Digest, Vol 26, Issue 4
Many thanks
On Thu, Aug 11, 2016 at 9:00 PM, <[email protected]<mailto:[email protected]>> wrote:
Today's Topics:
Message: 1
From: Christoph Reinhart <[email protected]<mailto:[email protected]>>
To: DAYSIM discussion <[email protected]<mailto:[email protected]>>
Message-ID:
        <1B23446CBF250648A2FC775DE3FE7E80FF463DA1@OC11expo28.exchange.mit.edu<mailto:1B23446CBF250648A2FC775DE3FE7E80FF463DA1@OC11expo28.exchange.mit.edu>>
-I haven't used the new version of DIVA yet, so maybe someone else can answer this question more detailed. I know you can go two approaches, either you define a node in W/m*m and run an annual simulation with daysim OR you run an irradiation map with gencumulativesky ,but I'm not sure where to invoke the latter one in the new version.
URL: <http://www.radiance-online.org/pipermail/radiance-daysim/attachments/20160811/a95e46a8/attachment-0001.html&gt;
Message: 2
From: Abigail Chi <[email protected]<mailto:[email protected]>>
To: [email protected]<mailto:[email protected]>
Message-ID:
        <CAPSjnYiYWUBC2uO_N4sXOvCTmRV8q4hrrmDKjSrZhC3xrNXb3Q@mail.gmail.com<mailto:CAPSjnYiYWUBC2uO_N4sXOvCTmRV8q4hrrmDKjSrZhC3xrNXb3Q@mail.gmail.com>>
Many thanks
Message: 2
From: Jan Wienold <[email protected]<mailto:[email protected]>>
Message-ID: <[email protected]<mailto:[email protected]>>
Hi Abigail,
in the header-file.
good luck!
Jan/
> Hi Jan
0036261119/Tn
> transmittance?
> Daysim interface.
> in Daysim?
> Many thanks
URL: <http://www.radiance-online.org/pipermail/radiance-daysim/attachments/20160811/e27bb27c/attachment-0001.html&gt;
