rad3R5 from latest stable cvs doesn't compile
I'm having problems compiling radiance from sources from radiance-online cvs. I downloaded the stable tarball and am able to compile most of the executables, but it errors in the src/px dir every time. It seems that the tiff directory is the cause of the problem. It appears that the configure script is borked in some way. I have run the script manually and end up with the same results:
It seems to fill the resulting Makefile with random spew
Warning, this file was automatically created by the TIFF configure script#Warning, this file was automatically created b
y the TIFF configure script Warning, this file was automatically created by the TIFF configure script@Warning, this file
  was automatically created by the TIFF configure scriptWWarning, this file was automatically created by the TIFF configu
re scriptAWarning, this file was automatically created by the TIFF configure scriptRWarning, this file was automatically
  created by the TIFF configure scriptNWarning, this file was automatically created by the TIFF configure scriptIWarning,
  this file was automatically created by the TIFF configure scriptNWarning, this file was automatically created by the TI
FF configure scriptGWarning, this file was automatically created by the TIFF configure script@Warning, this file was aut
is all one line. This behaviour continues in the version, libdirs, machine type, and random(?) lines throughout the file. This causes make to bomb out with a missing separator error during the compile.
I'm wondering if this is a local toolchain problem, or if anyone else has experienced this behaviour. I'm compiling on a linux system (gentoo), which has been compiled from scratch using this same toolchain - gcc 3.2.1, glibc 2.3.1, and the gnu toolset. I have invoked the makeall script from a tcsh shell.
any ideas?
tom
Hi Tom,
I've had the same problem compiling radiance on SuSE-Linux, Version 8.1.
The trouble was caused by sed version 3.02.xx(in conjunction with the
variable POSIXLY_CORRECT in the configure-script). As far as I know,
when
POSIXLY_CORRECT is set, the sed versions(I tried out version 3.02.51,
3.02.60
and 4.06) insert the replacement string before each character in the
matched
line, e.g. the command sed "/@VERSION@/s;;v3.4beta037;g" applied to
# VERSION: @VERSION@"
will result in
v3.4beta037#v3.4beta037
v3.4beta037Vv3.4beta037Ev3.4beta037Rv3.4beta037Sv3.4beta037Iv3.4beta037Ov3.4beta037Nv3.4beta037:v3.4beta037
v3.4beta037@v3.4beta037Vv3.4beta037Ev3.4beta037Rv3.4beta037Sv3.4beta037Iv3.4beta037Ov3.4beta037Nv3.4beta037@v3.4beta037
whereas sed 3.02 generates
# VERSION: v3.4beta037
I handled this problem by reverting back to sed version 3.02.
Maybe you can remove/comment out the line
POSIXLY_CORRECT=1; export POSIXLY_CORRECT # disable GNU extensions
in ray/src/px/tiff/configure, but I don't know if this leads to any side
effects.
Augustinus
tom wrote:
any ideas?
tom
Augustinus Topor wrote:
Hi Tom,
<snip of very good analysis of problem>
effects.
Augustinus,
I am using sed 4.05. I commented out the line in the configure script and everything appeared to compile - including ra_tiff and friends. It appears that oconv and rpict and rview seem to work, but I'm still left with a nonworking ximage. Time to fiddle around a little more :slight_smile:
Thank you for the help,
tom
radiance-online cvs. I downloaded the stable tarball and a...
compile most of the executables, but it errors in the src/...
Too many errors encountered; the rest of the message is ignored:
time.
I am running Red Hat 9. I saw Tom had a similar problem back in April.
What I did not see is if he ever got it working and how.
Etienne
Get a FREE online virus check for your PC here, from McAfee. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
etienne canard wrote:
Actually, the CVS HEAD dump is usually more stable than the
so called "official release"...
time.
Most likely you left out step 2. of the installation instructions
as given on the download page:
  2. download the ball of auxiliary files
The contents of this archive are necessary for both releases
to build correctly.
-schorsch
I do have both files. The programs I am left without are ximage,xshowtrace and xyzimage. This is the error I am recieving:
cd libtiff ; make install
make[1]: Entering directory `/Working/Software/Radiance3.HEAD/ray/src/px/tiff/libtiff'
Makefile:31: *** missing separator. Stop.
make[1]: Leaving directory `/Working/Software/Radiance3.HEAD/ray/src/px/tiff/libtiff'
make: *** [../lib/libtiff.a] Error 2
gcc -I../common -L../lib -O2 -DSPEED=200 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/
make: Target `install' not remade because of errors.
Reply-To: radiance-general@radiance-online.org
Subject: Re: [Radiance-general] rad3R5 from latest stable cvs doesn't compile
Date: Sun, 18 Jan 2004 16:16:40 -0500 (EST)
> Hi all,
> time.
to build correctly.
-schorsch
In the followup post to mine in the archives, there is a workaround to this same problem. The last time I built the 'official' release (to use Roland's pmap addition), I just copied my system libtiff and headers into the Radiance source tree and built/linked against these. Everything built and seemed to function correctly. The included libtiff configure process doesn't seem to like newer versions of GNU sed - or vise versa :wink:
tom
This sounds very familiar. My solution was to edit the RMakefile
in src/px to link to the existing system libraries. This was as
simple as:
186c186
< ra_tiff: ra_tiff.o ../lib/libtiff.a
ra_tiff: ra_tiff.o /usr/lib/libtiff.a
189c189
< ../common/tiff.h ../common/tiffio.h: ../lib/libtiff.a
../common/tiff.h ../common/tiffio.h: /usr/lib/libtiff.a
193c193
< normtiff: normtiff.o ../lib/libtiff.a
normtiff: normtiff.o /usr/lib/libtiff.a
Mark
Thanks Tom for sharing your solution. It did the trick. As you may have deduced, I do not have a healthy amount of compiling experience.
Date: Sun, 18 Jan 2004 20:33:56 -0800
tom
Rethink your business approach for the new year with the helpful tips here. http://special.msn.com/bcentral/prep04.armx
