I can't believe I've never had to do this before, but I need to take a Radiance model and convert it back to dxf (or dwg, or obj). Is there such a utility or workflow?
Hi Rob,
I once did that going via mgf and vrml:
rad2mgf scene.rad > scene.mgf
mgf2inv -vrml scene.mgf > scene.wrl
This vrml file can then be imported to e.g. Rhino. However, I did not get
different layers for different materials, but I also didn't look into that,
because I just wanted to check the geometry...
David
2013/1/22 Rob Guglielmetti <[email protected]>
utility or workflow?- Rob
Thanks David,
I was just writing an update myself:
I found that Francesco Anselmo wrote a nice radiance to obj script in Python:
http://www.bozzograo.net/radiance/pub/rad2obj.py
On Jan 22, 2013, at 9:46 AM, David Geisler-Moroder <[email protected]> wrote:
Hi Rob,
mgf2inv -vrml scene.mgf > scene.wrlThis vrml file can then be imported to e.g. Rhino. However, I did not get different layers for different materials, but I also didn't look into that, because I just wanted to check the geometry...
David2013/1/22 Rob Guglielmetti <[email protected]>
I can't believe I've never had to do this before, but I need to take a Radiance model and convert it back to dxf (or dwg, or obj). Is there such a utility or workflow?- Rob
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
Hi Rob,
You can convert from Radiance to MGF, then from there to Inventor format, which someone might read. (rad2mgf followed by mgf2inv) Inventor is supported at some level by Autodesk.
Date: January 22, 2013 8:34:13 AM PSTI can't believe I've never had to do this before, but I need to take a Radiance model and convert it back to dxf (or dwg, or obj). Is there such a utility or workflow?
Thanks all.
For the record, I used Francesco's script to go from radiance to obj, then
imported that into Blender and saved as a 3ds, which I was then able to
import into SketchUp. Seems to have worked...
On 1/22/13 9:49 AM, "Greg Ward" <[email protected]> wrote:
Hi Rob,
supported at some level by Autodesk.-Greg
Hey Rob,
It had to happen some day....
rad2mgf perhaps gets you part way, not sure if mgf2inv might get you the next step?
Jack de Valpine
President
Visarc Incorporated
channeling technology for superior design and construction
I am currently looking into the use of hdr images and their use with evalglare.
Can anyone tell me (before I launch into it) whether it's possible to use the 'standard' lens on my camera or does evalglare require a hemispherical image as an input?
Quick to check I know, but also quick to mail all you lovely people!
