Today's Topics:
1. Questions concerning rcontrib & three-phase-method (Zhe Kong)
2. Re: Questions concerning rcontrib & three-phase-method (Greg Ward)
3. Re: Questions concerning rcontrib & three-phase-method
(Gregory J. Ward)
Message: 1
Date: Wed, 28 Sep 2016 20:37:13 -0500
To: [email protected]
Subject: [Radiance-general] Questions concerning rcontrib &
three-phase-method
Message-ID:
<CAEV5Nyf_qXrKkLjmNoz9=HnEyF3hyCyMYVfW8-X2Jvv7_EzAyw@mail.
gmail.com>
Dear Radiance Users:
I am learning rcontrib & three-phase-method recently and I have a few
questions.
1) In rcontrib_less 4.3, I ran the command to produce point illuminance:
$ cat data/photocells.pts | rcontrib -h -I -fo @rtc.opt -e MF:1 -f
reinhart.cal -b rbin -o results/sensors/p%03d.dat -m sky_glow -w
restroom_whitesky1.oct
However, the error I got is:
rcontrib: fatal - unspecified or illegal bin count for modifier 'sky_glow'
2) In 3-phase-method, When I run the command to generate two view matrices:
$ vwrays -ff -vf views/back.vf -x 600 -y 600 | rcontrib 'vwrays -vf
views/back.vf -x 600 -y 600 -d' -ffc -fo -o images/vmx/window_%03d.hdr -f
klems_int.cal -b kbinS -bn Nkbins -m windowglow -ab 12 -ad 50000 -lw 2e-5
model_vmx.oct
I got: rcontrib: fatal - missing required modifier argument
I couldn't get much information to solve either of the issues above from
the mailing list. Any suggestion is appreciated.
Thank you,
*Zhe Kong*
*PhD Student*
*University of Wisconsin - Milwaukee *
*School of Architecture and Urban Planning *
*2131 E. Hartford Ave, Milwaukee, WI 53211 *
*Office 327*
URL: <http://www.radiance-online.org/pipermail/radiance-
general/attachments/20160928/fd238f0b/attachment-0001.html>
Message: 2
Date: Thu, 29 Sep 2016 11:20:26 -0700
Subject: Re: [Radiance-general] Questions concerning rcontrib &
three-phase-method
Hello Zhe,
It's unfortunate that at the moment, we have only incomplete or withdrawn
tutorials covering the 3-phase method. I hope we will be able to remedy
this at some point. You are actually better off using rfluxmtx instead of
rcontrib in most cases, as it simplifies operations and incorporates a more
generalized version of genklemsamp.
For example, your first command, which must be the basic daylight
coefficient (2-phase) method:
will run if you add the option "-bn Nrbins" near the "-b" option above,
but can be replaced with the simpler call to rfluxmtx:
rfluxmtx -I @rtc.opt -w - sky.rad -i restroom_nosky.oct <
data/photocells.pts
Do not forget the lone hyphen ('-') above -- it tells rfluxmtx to read the
sender positions from stdin rather than generating them itself. Also, the
receiver file "sky.rad" should not be included in the octree
"restroom_nosky.oct", but should look like this:
#@rfluxmtx o=results/sensors/daycoeff.dat
#@rfluxmtx h=u
void glow groundglow
4 1 1 1 0
groundglow source ground
4 0 0 -1 180
#@rfluxmtx h=r4 u=+Y
void glow skyglow
4 1 1 1 0
skyglow source sky
4 0 0 1 180
The special comments are very important, as they tell rfluxmtx how to
handle each hemisphere and what to do with the data. (You could also have
used the -o option on the command line as before in this case.) Note that
I have removed the "%d" from the file name, because you would have ended up
with two sets of coefficients for each sensor point in bin #0. I am not
sure about the rest of the commands in your sequence, so you'll have to
figure out how to work with the rearranged output, which will now be in
columns of triplets, one triplet for the ground followed by a triplet for
each of the 145 sky patches. Each sensor will thus be represented by 146x3
coefficients in each row of the output matrix "results/sensors/daycoeff.dat"
Some of this is explained in my 2014 "What's New" talk from London:
http://www.radiance-online.org/community/workshops/2014-
london/presentations/day1/Ward_WhatIsNew.pdf
Your second command can also be replaced with a simpler rfluxmtx version,
but the actual problem appears to be your substitution of single quotes (')
in place of the special back-quote character (`) when you call vwrays with
the -d option to set the output image dimensions.
> From: Zhe Kong <[email protected]>
> Date: September 28, 2016 6:37:13 PM PDT
questions.
> cat data/photocells\.pts | rcontrib \-h \-I \-fo @rtc\.opt \-e MF:1 \-f
reinhart\.cal \-b rbin \-o results/sensors/p%03d\.dat \-m sky\_glow \-w
restroom\_whitesky1\.oct
> rcontrib: fatal \- unspecified or illegal bin count for modifier
'sky\_glow'
> 2\) In 3\-phase\-method, When I run the command to generate two view
matrices:
model_vmx.oct
> Thank you,
> Zhe Kong
> PhD Student
> Office 327
general/attachments/20160929/58515be2/attachment-0001.html>
Message: 3
Date: Thu, 29 Sep 2016 11:23:48 -0700
three-phase-method
Content-Type: text/plain; charset=us-ascii
I spotted an error in my example file, which should have h=r1 rather than
h=r4 to match your sampling case:
#@rfluxmtx h=u
4 1 1 1 0
4 0 0 -1 180
#@rfluxmtx h=r1 u=+Y
void glow skyglow
4 1 1 1 0
skyglow source sky
4 0 0 1 180
Subject: Digest Footer
End of Radiance-general Digest, Vol 151, Issue 6
