I am very new to Radiance. I am trying to model roller shades with iso2klems (Original post about iso2klems), but encounter some errors. (bsdf2ttree works for me, and I have Radiance on Window.)
I tried both window cmd and perl with no luck. Any help/suggestion is appreciated!
This seems to be a bug in iso2klems, which has not been tested properly on Windows. I have checked in a new version, which may fix the problem. You can download it from the CVS site.
It looks as though you are just copying the “Usage” information to the command line, rather than giving it an input file as it suggests. The words in brackets are optional. The brackets should never literally be given to the command. Your command should look more like the example I gave in my last reply.
I converted the iso2klems.pl to iso2klem.exe, and tried to type the command you suggested (iso2klems). However, I still just received the “Usage” information.
