I am wondering if there is a way to get Radiance to work with Autodesk
Architectural desktop 2005? I can't seem to get the two to interface
correctly. I need it for basic daylighting simulations. Thanks
Brien Rakoci
Associate
fm | SOLUTIONS
Phone: 602-393-7562
Fax: 602-265-9477
4001 North 3rd Street
Suite 250
Phoenix, Arizona 85012
http://www.facilitize.com <blocked::http://www.facilitize.com/>
Hi Brine,
As far as I know desktop radiance only works with Autocad 2000, If you are
trying to install the same on Architectural desktop 2005 It will not work
for my experience too. If you are using a Windows OS , there are
some binaries written, you might want to check
http://www.bozzograo.net/radiance/index.php by Francesco Anselmo. they are
very very helpful. If you have questions you can call me at 480.544.4936. I
live in tempe.
bye
Aditya Potipireddi
MS Building Design ( Energy & Climate)
Arizona State University
2008/3/26 Brien Rakoci <[email protected]>:
Brien Rakoci
Associate
*fm** *| SOLUTIONS
Phone: 602-393-7562
Fax: 602-265-9477
Suite 250
Aditya Potipireddi
tel. 480.544.4936
Dear all,
Actually, I am a new user of Radiance, so I have very basic questions regarding this software.
First, I wanted to know whether it can be installed and used on Windows operating systems or it should be used only on Mac.
Also, the older versions of Radiance can be used as a plugin in Autodesk Ecotect. So I wanted to know whether using Radiance with Ecotect would give the same accurate results as using Radiance itself.
Regards,Maryam
Hi Maryam,
It seems that no one has responded to your query, which is unfortunate. We need a FAQ of some sort for these questions, but don't have one at the moment.
Radiance runs best on some version of Unix, but there is of course an installer for Windows as you noted. I do not know the current state of Ecotect or whether it is recommended. There are other interfaces available, such as NREL's OpenStudio and DIVA. There is a fair amount of information in the mailing archives on both, and they have websites you should find easily enough as well.
Best of luck!
Subject: [Radiance-general] Question
Date: June 1, 2015 12:41:06 PM PDT
Dear all,
Maryam
Hi Maryam,
A Building Performance article on Radiance from way back (1998) may still be useful to help understand the essential difference between UNIX Radiance and any of the 'packaged' (i.e. non-UNIX) versions. Although none of the PC versions mentioned still exist, the general gist of the article still holds. The article was included as Appendix C (Chapter 7) here:
http://climate-based-daylighting.com/doku.php?id=resources:thesis
Best
John
John Mardaljevic PhD FSLL
Professor of Building Daylight Modelling
School of Civil & Building Engineering
Loughborough University
Loughborough
Leicestershire
LE11 3TU, UK
Tel: +44 1509 222630 (Direct)
[email protected]<mailto:[email protected]>
http://www.lboro.ac.uk/departments/civil-building/staff/mardaljevicjohn/<http://www.lboro.ac.uk/departments/civil-building/staff/mardaljevicjohn>
Personal daylighting website:
http://climate-based-daylighting.com<http://climate-based-daylighting.com/>
[cid:D599A67F-1B02-4789-B332-FB39946891CB@home]
