Question concerning installing Radiance in Mac
Hi Zhe,
It looks like apple removed some GL support in the version of OS X you are using, which is too bad. You will need to edit src/util/Rmakefile and remove the program "glrad" from the PROGS= setting near the top. Then, rerun "rmake install" in that directory.
You didn't include all of your compile listing, so it's difficult to know why rpict is not found, but did you remember to do as it suggested at the end and add "/Applications/radiance/ray/bin" to your PATH variable? I don't know why you decided to put everything there rather than /usr/local, but in any case, the shell won't find commands unless it knows where to look for them.
Subject: [Radiance-general] Question concerning installing Radiance in Mac
Date: May 13, 2015 9:10:03 AM PDT
Hi all:
I’m starting to learn Radiance and tried to install it in Mac. I followed the video of installation online and got errors in attachment. I ran a test and got another error in the second attachment.
Could someone let me know how I should fix it?
Thank you in advance.
Zhe
Zhe,
The one error that is visible in your screenshot isn't what cause rpict to
fail to compile. There are probably more errors above in the terminal
window if you scroll up. Can you copy all the text from when you started to
compile alll the way to the end into an email? Just use copy paste rather
than attaching screenshot images.
Andy
On Wed, May 13, 2015 at 9:10 AM, zhekong <kongzhewode@gmail.com> wrote:
Hi all:
I'm starting to learn Radiance and tried to install it in Mac. I followed
Zhe
