Question About Radiance Converstion Programs
Dear Group
I have some questions concerning some of the existing utilities in Radiance for pattern mapping. I have written a conversion program myself. I based the mapping of patterns onto polygons on a cal file x2ruvmap.cal written by Ole Lemming for Conrad. It does its job well but this cal file is fairly long and I think that it may be hampering performance. It seems the conversion of uv coordinates to barycentric coordinates for patterns is done at render time rather than the file conversion stage. For hundreds of millions (if not billions) of ray hits, this can be quite costly. Then again, I may be wrong. I have looked into tmesh.cal and I believe that the approach taken here is much more efficient. My goal is to utilize the approach and routines in the existing source code to implement into my conversion program. I have done some research through some of the source code and I have some questions.
While looking through obj2rad.c, it is mentioned in a comment block that the texture map indices were taken out. May I ask why? Do mapping of 2d images on polygons work with obj2rad/obj2mesh? Also while looking through obj2rad.c, I noticed that there are steps to output a reversed triangle. It has been my understanding that polygons in Radiance are 2 sided and as such, they are visible on both sides. The only time I know when surface normal orientation is critical is when setting up polygons for usage with mkillum for mimicking windows and other apertures within a building. Why is it done here? As I looked through tmesh.c in the function comp_baryc, the order of the vertices are rotated. Out of curiosity, why?
Regards
Marcus
Store more e-mails with MSN Hotmail Extra Storage � 4 plans to choose from! http://click.atdmt.com/AVE/go/onm00200362ave/direct/01/
Hi Marcus,
Sorry for the slow response -- this one fell through the cracks (growing wider by the minute).
I took texture coordinates out of obj2rad because I didn't have any working texture examples, and had some unresolved questions about handling texture (image) files and getting the mappings to work out. However, texture coordinates are fully implemented in the obj2mesh code, which is the method I recommend because it doesn't need to interpret any .cal files, which can be costly as you point out, even if they're well-written.
As for surface normals, most surfaces are indeed two sided, but not all, and in cases where you need surface orientation (e.g., dielectric solids), the normal interpolation will not work correctly if the vertex normals are opposite to the face normals. This is why there is some code for reversing them in obj2rad and obj2mesh.
I hope this helps.
Date: March 4, 2004 7:14:06 AM PST
Dear Group
Regards
Marcus
