Question about dctimestep
Dear Radiance Users:
I am struggling with 3-phase method and run into an issue about dctimestep.
At the last step of the tutorial (
https://andymcneil.gitbooks.io/three-phase-method-tutorial/content/35_matrix_multiplication.html\)
to use dctimestep to calculate illuminance for three shading systems:
$dctimestep results/photocells.vmx data/Clear.xml results/south.dmx
skies/12_21_15.skv rcalc -e '$1=179*($1*0.265+$2*0.670+$3*0.065)' >
results/illum_122115_clear.dat
At first I received the feedback below:
Usage: dctimestep [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]
or: dctimestep [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf
Dmat.dat [skyf]
From this post:
http://radiance-online.org/pipermail/radiance-general/2013-October/009833.html
I think my dctimestep is not the newest one, so I download it from
http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/src/util/dctimestep.c?annotate=2.37
My question is how to install it appropriate. I saved the file as
dctimestep and use $chmod a=r+w+x dctimestep, I got the errors as below:
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 2: static:
command not found
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 4:
/Applications: is a directory
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 5:
apply_overcast.bash: command not found
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 6:
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 7:
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 8: data/:
is a directory
and so on. The list is a bit long to include all. I don't think I install
it right. Could someone let me know how to replace dctimestep correctly, if
this is the problem, or what is the solution to make this step work?
Thank you very much in advance.
Zhe Kong
Zhe Kong
Hi Zhe,
If the command that you wrote in your email is the exact one that you used, then you should correct it by putting a | before rcalc as the output from dctimestep is being piped to rcalc through standard input.
This…..
$dctimestep results/photocells.vmx data/Clear.xml results/south.dmx skies/12_21_15.skv rcalc -e '$1=179*($1*0.265+$2*0.670+$3*0.065)' > results/illum_122115_clear.dat
should be ….
$dctimestep results/photocells.vmx data/Clear.xml results/south.dmx skies/12_21_15.skv | rcalc -e '$1=179*($1*0.265+$2*0.670+$3*0.065)' > results/illum_122115_clear.dat
Sarith
Sent: Thursday, October 13, 2016 5:43 PM
Subject: [Radiance-general] Question about dctimestep
At the last step of the tutorial (https://andymcneil.gitbooks.io/three-phase-method-tutorial/content/35_matrix_multiplication.html\) to use dctimestep to calculate illuminance for three shading systems:
or: dctimestep [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]
From this post: http://radiance-online.org/pipermail/radiance-general/2013-October/009833.html I think my dctimestep is not the newest one, so I download it from http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/src/util/dctimestep.c?annotate=2.37
My question is how to install it appropriate. I saved the file as dctimestep and use $chmod a=r+w+x dctimestep, I got the errors as below:
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 2: static: command not found
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 4: /Applications: is a directory
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 5: apply_overcast.bash: command not found
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 6: apply_overcast.bash: command not found
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 7: apply_overcast.bash: command not found
/Users/zhekong/Radiance/usr/local/radiance/bin/dctimestep: line 8: data/: is a directory
and so on. The list is a bit long to include all. I don't think I install it right. Could someone let me know how to replace dctimestep correctly, if this is the problem, or what is the solution to make this step work?
Zhe Kong
Zhe Kong
Hello Sarith:
Thank you for your reply. Yes, you are right. It's the '|' missing rather
than dctimestep version. Thank you for leading me to the right path.
Zhe
On Fri, Oct 14, 2016 at 2:00 PM, < [email protected]> wrote:
Today's Topics:
   1. Question about dctimestep (Zhe Kong)
   2. Re: Question about dctimestep (Sarith Subramaniam)
Message: 1
Date: Thu, 13 Oct 2016 16:43:10 -0500
Message-ID:
        <CAEV5Nyc8MvSCu7tMRdAr-13F2ijrMCbijbxZT42LqN7_VEnm9w@
mail.gmail.com>
tutorial/content/35_matrix_multiplication.html)
Dmat.dat [skyf]
>From this post:
command not found
is a directory
Zhe Kong
Zhe Kong
URL: <http://www.radiance-online.org/pipermail/radiance-
general/attachments/20161013/8487cd21/attachment-0001.html>
Message: 2
Date: Thu, 13 Oct 2016 17:48:56 -0400
To: "'Radiance general discussion'"
        <[email protected]>
Subject: Re: [Radiance-general] Question about dctimestep
Hi Zhe,
This?..
should be ?.
Sarith
io/three-phase-method-tutorial/content/35_matrix_multiplication.html) to
Dmat.dat [skyf]
is a directory
Zhe Kong
Zhe Kong
general/attachments/20161013/1157e843/attachment-0001.html>
Subject: Digest Footer
End of Radiance-general Digest, Vol 152, Issue 9
*Zhe Kong*
*PhD Student*
*University of Wisconsin - Milwaukee *
*School of Architecture and Urban Planning *
*2131 E. Hartford Ave, Milwaukee, WI 53211 *
*Office 327*
