When using the pvalue command, and using the -b option to obtain the
brightness, what are the resulting units for each pixel if I'm working in
radiance units?
Thanks in advance!
adriana
radiance units?
Thanks in advance!
adriana
Hi Adriana,
If you use the -o option of pvalue, then the output of the -b option is watts/steradian/meter^2 and should be multiplied by the standard conversion factor of 179 lumens/watt to get to candelas/meter^2 (or nits). A candela is a lumen/steradian.
Date: March 27, 2006 5:03:07 PM PSTHi all,
radiance units?Thanks in advance!
adriana
