and checking to see if the luminance from the pvalue output for a given
pixel matches the luminance for the same pixel when clicked on in
Photosphere. (I am doing this to create a powerpoint slide that
illustrates that luminance can be extracted from each pixel in a radiance
image for a very general audience).
(Actually i click a pixel on the image in Photosphere and then track down
it's record in the pvalue output)
I noticed that the 0,0 Origin in Photosphere is the upper left corner, and
for Radiance images it is the lower left (i believe ? ).
Since my image is 1536 x 1536 pixels, pixel x=256,y=550 in Photosphere is
then row:
x=256, y=abs(550 - 1536), brightness.value
. . . . as output from Pvalue.
I take brightness.value*179 to get my pixel luminance and it matches
closely with the output from Photosphere, but not exactly. I want to ask
if I am using the correct conversion from pvalue's output to luminance,
and that my understanding of the (0,0) origin locations in Radiance and
Photosphere is correct.
I'm a relatively new user so any help would be appreciated!
Kyle
Kyle Konis
PhD Student
Lawrence Berkeley National Lab (LBNL)
UC Berkeley Center for the Built Environment (CBE)
206.303.9786
You have the conversion factor (179) correct, and the coordinate translation *almost* correct -- you actually have to subtract the y value from ymax-1 (rather than ymax) to get the exact coordinate.
then row:
