I am not sure whether this would break anything, but it would be a rather useful way of organizing renderings:
At the moment, I can pass a view name to rad using the -v parameter, and this will cause exactly one view to be rendered, which must have been named in the view= line in the rif file.
Now, this view= line can point to a view file, which may contain more then one view. I would have expected rad to render all the views in that file, but as -v is defined to render exactly one view, rad takes only one of the views defined in the view file and ignores the others.
I would propose to change this behaviour. If I call rad e.g. as
rad -v myview myoctree.oct
it would be very useful if rad would look whether it finds a view= line for myview. If it finds one defining one view, render that. If it finds one pointing to a view file, render all the views in that view file. If I call rad as
rad -v anotherview -v myview myoctree.oct
it should render all views defined in the view= lines for anotherview and myview, be it view files or view definitions inside the rif.
One reason this would be helpful is as such: I am currently working on a scene, which needs some view-dependent processing. So I have a script which does some work, cleans up, creates an octree, creates photon maps, and then calls rad. Now I would like to call the same rif-file for all of these, as it eventually contains the same information for all renderings except the views. And I cannot render all views at once, as I have to modify the octree before moving to the next "view group" (this translates to rooms in my example).
I am sure that there are other uses for this. What do you think? Is there any way people may have used the -v parameter that could imply the risk of breaking compatibility by introducing such a change?
Cheers Lars.
Lars O. Grobe (Mr) :: Research Fellow, Solar Energy Research Institute of Singapore SERIS :: National University of Singapore :: 7 Engineering Drive 1, Block #E3A-06-35, Singapore 117576 :: 65-6516 5816(Tel) :: 65-6775 1943 (Fax) :: [email protected] (E) :: www.seris.sg (W) :: Company Registration No: 200604346E
Important: This email is confidential and may be privileged. If you are not the intended recipient, please delete it and notify us immediately; you should not copy or use it for any purpose, nor disclose its contents to any other person. Thank you.
