A view file is supposed to represent one (1) view. The last line of the view file is considered to be the view spec. Considering a view file to be a collection of multiple views is counter productive.
It seems to me that there are a few ways to do what you want:
1. create multiple rif files with each one representing a "view
group" and containing multiple "view=" lines, note this is really
one of the things that rif file is for, that is to create coherent
groupings of views with respect to a set of
geometry/materials/lighting as defined in an octree....
2. enhance your script to include a separate "view group" file, the
script can parse the view group file and pass the relevant views
to the rif file, in essence building a rif file on the fly....
3. ranimate, as Thomas suggests, you could probably do something with
the ANIMATE parameter for ranimate pointing to a script to produce
the correctly modified octree and use a VIEWFILE with all your
views in it.
Thomas Bleicher wrote:
Have you considered using ranimate here?
On Wed, Jul 22, 2009 at 9:05 AM, Lars O. Grobe<[email protected]> wrote:
I am not sure whether this would break anything, but it would be a rather
useful way of organizing renderings:At the moment, I can pass a view name to rad using the -v parameter, and
this will cause exactly one view to be rendered, which must have been named
in the view= line in the rif file.Now, this view= line can point to a view file, which may contain more then
one view. I would have expected rad to render all the views in that file,
but as -v is defined to render exactly one view, rad takes only one of the
views defined in the view file and ignores the others.I would propose to change this behaviour. If I call rad e.g. as
rad -v myview myoctree.oct
it would be very useful if rad would look whether it finds a view= line for
myview. If it finds one defining one view, render that. If it finds one
pointing to a view file, render all the views in that view file. If I call
rad asrad -v anotherview -v myview myoctree.oct
it should render all views defined in the view= lines for anotherview and
myview, be it view files or view definitions inside the rif.One reason this would be helpful is as such: I am currently working on a
scene, which needs some view-dependent processing. So I have a script which
does some work, cleans up, creates an octree, creates photon maps, and then
calls rad. Now I would like to call the same rif-file for all of these, as
it eventually contains the same information for all renderings except the
views. And I cannot render all views at once, as I have to modify the octree
before moving to the next "view group" (this translates to rooms in my
example).I am sure that there are other uses for this. What do you think? Is there
any way people may have used the -v parameter that could imply the risk of
breaking compatibility by introducing such a change?Cheers Lars.
Lars O. Grobe (Mr) :: Research Fellow, Solar Energy Research Institute of
Singapore SERIS :: National University of Singapore :: 7 Engineering Drive
1, Block #E3A-06-35, Singapore 117576 :: 65-6516 5816(Tel) :: 65-6775 1943
(Fax) :: [email protected] (E) :: www.seris.sg (W) :: Company Registration
No: 200604346EImportant: This email is confidential and may be privileged. If you are not
the intended recipient, please delete it and notify us immediately; you
should not copy or use it for any purpose, nor disclose its contents to any
other person. Thank you._______________________________________________
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
# Jack de Valpine
