Hi everyone,
I am having a weird issue with the RAD command. Radiance is running on my
machine: I checked my scene before and had no issue with using oconv on my
scenes and then using rvu to check out the octree. But once I set set up my
.rif file and run "rad summer.rif" I get the following error:
oconv mod3.rad summer_sky.rad > summer.oct
oconv: system - cannot open scene file "mod3.rad": No such file or directory
rad: error generating octree
summer.oct removed
If I change the filename in my .rif for mod3.rad I get a different error
("no such file") so it should be pointing to the right file. Any
suggestions? I'm running radiance on a Windows7 machine. I'm pretty sure I
downloaded the files from NREL's openstudio site. Any suggestions? I've
attached my files - they're pretty simple.
Alex Krickx
mod3.rad (12.5 KB)
summer.rif (376 Bytes)
summer_sky.rad (358 Bytes)
*Alex Krickx, LEED AP*
Project Engineer**
*________________________________*****
I N T E G R A L****
* ** **GROUP*****
427 13th Street, Oakland CA 94612
510 663 2070 x 247****
www.integralgroup.com****
*DEEP GREEN Engineering.*
*_______________________________*
At first blush, that looks like maybe you don't have your current directory (".") in your search path. Assuming those two files are in your current dir, try:
oconv ./mod3.rad ./summer_sky.rad > summer.oct
If that works, then you can add "." to your path.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 10/18/12 10:22 AM, "Alex Krickx" <[email protected]<mailto:[email protected]>> wrote:
Hi everyone,
I am having a weird issue with the RAD command. Radiance is running on my machine: I checked my scene before and had no issue with using oconv on my scenes and then using rvu to check out the octree. But once I set set up my .rif file and run "rad summer.rif" I get the following error:
summer.oct removed
If I change the filename in my .rif for mod3.rad I get a different error ("no such file") so it should be pointing to the right file. Any suggestions? I'm running radiance on a Windows7 machine. I'm pretty sure I downloaded the files from NREL's openstudio site. Any suggestions? I've attached my files - they're pretty simple.
Alex Krickx
Project Engineer
I N T E G R A L
GROUP
510 663 2070 x 247
www.integralgroup.com<http://www.integralgroup.com/>
Hi Rob,
Thanks for your response. The files are indeed in my current directory - I
thought the path was ok because when I type in "oconv mod3.rad
summer_sky.rad > summer.oct" without "./"s into the command editor I
generate the octree correctly - am I mistaken?
Alex
Project Engineer**
I N T E G R A L****
* ** **GROUP*****
On Thu, Oct 18, 2012 at 9:36 AM, Guglielmetti, Robert < [email protected]> wrote:
current dir, try:
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 10/18/12 10:22 AM, "Alex Krickx" <[email protected]<mailto: > [email protected]>> wrote:
Hi everyone,
directory
summer.oct removed
Alex Krickx
Project Engineer
I N T E G R A L
GROUP
510 663 2070 x 247
You can try Rob's suggestion, but I checked the code, and there is no search going on by oconv for input files. Therefore, I suspect something is wrong with your file permissions. If you can "cat" the file using "cat mod3.rad" in the same directory, then try running oconv by hand to see if that works -- just copy and paste what rad produces before the error.
This won't solve your problem, but it may help to figure out what's going wrong.
Date: October 18, 2012 9:36:54 AM PDT
Rob Guglielmetti
Hi everyone,
summer.oct removed
Alex Krickx
Project Engineer
This doesn't really make sense, since rad calls system() with the same command line. If you can cut and paste from the rad output to the command prompt and that works, then rad should work, also. It works fine on my Unix system. I'm stumped.
Date: October 18, 2012 9:49:04 AM PDT
Hi Rob,
Thanks for your response. The files are indeed in my current directory - I thought the path was ok because when I type in "oconv mod3.rad summer_sky.rad > summer.oct" without "./"s into the command editor I generate the octree correctly - am I mistaken?
Alex
Project Engineer
Thanks to Greg and Rob,
Turns out it was a Windows OS issue (surprise surprise). Just to share what
I learned with the list - Windows can have certain permissions issues that
prevent Radiance from running correctly. We also found a weird Registry
value (yikes!) that was the main culprit.
Adding a "." to my path also may have solved my problem - in any case I'm
keeping it in there for good measure. Now to do some scene rendering...
Alex Krickx
Project Engineer**
I N T E G R A L****
* ** **GROUP*****
*Date: *October 18, 2012 9:49:04 AM PDT
Hi Rob,
Alex
Project Engineer
Thanks for the update, Alex, and glad you got it going. I'd be *really* interested in hearing what this registry value is all about, because the NREL installers do not touch the registry at all…
Turns out it was a Windows OS issue (surprise surprise). Just to share what I learned with the list - Windows can have certain permissions issues that prevent Radiance from running correctly. We also found a weird Registry value (yikes!) that was the main culprit.
Adding a "." to my path also may have solved my problem - in any case I'm keeping it in there for good measure. Now to do some scene rendering...
Alex Krickx
Project Engineer
I N T E G R A L
GROUP
510 663 2070 x 247
Hi Rob,
Alex
Project Engineer
