Problem with validation of Hyperspectral rendering
Hello everyone,
I am aware that the spectral simulation capability is still under development; however, I am trying to use it in my project. I built a scaled room 743 (1/10) and conducted spectral measurements (location: 35°47’49.4"N 51°24’48.7"E) at three depths with several different glasses using a spectrometer.
Here, I have provided the transmission data for three of the glasses that I measured with the spectrophotometer .
I performed spectral simulation based on the material information of the model (rad and mat files here) in the ALFA plugin and Radiance 6.0a, but the results are not encouraging :frowning:
In order to compare the spectral output of Radiance with ALFA, given that simulating 81 channels is currently not possible with -co as I understand, I modified one of the components of Lark plugin that was used to convert 9 channels into 400 channels so that I could also convert the output of 20 or 24 channels to 400 channels. (CSV file 380-780 5nm Exp,ALFA and Rad6.0)
At shallow depths, the performance of Radiance is close to the measurements I took, and at greater depths, the performance of ALFA is also close. I changed every parameter that I thought relevant, but I have not figured out where I went wrong (ipynb file)
Any suggestions would be greatly appreciated.
For deeper position try something like this, adjust ab, ad and lw until you see the values stabilize.
tr_params = pr.SamplingParameters(
    ab = 8,
    aa = 0,
    ad = 16384,
    lw = 0.00001,
    cs = 20,
    co = True,
If you have sky measurements, we recently introduced -L dirnorm difhor option to genssky, where dirnorm and difhor are for direct normal and diffuse horizontal illuminance. Running with this will give you a better integrated values. This option is not in pyradiance yet, but will be soon.
Hi Taoning,
Thank you
I have also performed simulations with similar and even higher settings, but there is still a significant difference compared to ALFA and Exp.
Has there been any comparison between the Radiance spectral simulation and other tools or exprimental measurements up to this point? ( except this [article] (https://publications.ibpsa.org/proceedings/bs/2021/papers/bs2021_30583.pdf))
I wasn’t aware of the new genssky feature. Thank you for letting me know! I’ll test it.
I am expecting quite a bit difference (>50% maybe) between your original one and the one I shared above. If you are not seeing any difference then there is something wrong with the process.
Make sure you set -lr -12 or so. Positive values of -lr are associated with low accuracy when -aa is 0
Hi dear Greg,
After a long time, today I see the edited version of your response. On that day, I tried with -lw and got:
rtrace: fatal - zero ray weight in Russian roulette (obviously :slightly_smiling_face:)
Also, I tested it now with -lr -12, but it didn’t have much effect. Now I figured out that aa = 0 was the main problem, and if set it to 0.1 or any other value except 0, there is absolutely a better result.
Best regards,
Soushiyant
OK, so long as you are happy. The error you got happens with a negative -lr value and a -lw value of 0, which is not a supported combination since it can lead to infinite recursion.
