i´am using radiance package installed via Diva for rhino 1.9 (i guess) in
windows7 64 professional
I want to make some simple calculations like those i´ll describe via Dos
command line
1- set the working directory where all my files are (obj, rad, oct, ies,
dat, pts)
2- obj2rad works fine
3- ies2rad also fine
4- oconv also
but a simplified rtrace calculation like this
5- rtrace filename.oct<filename.pts>filename.dat
gives me as result a file with just the header but no irradiance values for
the points in filename.pts
anyone knows what i´m doing wrong.
It´s because i´m not using cygwin, i mean, is the problem with my radiance
for window distribution? it woldn´t be the case as long as Diva is using
rtrace for its calculations without problems. At least it use to...
was my bad, pts file was incorrect (comma separated values) : S
it takes me 4 days to catch this silly problem!
cheers
aitor leceta
---------- Forwarded message ----------
Date: 2013/2/27
Subject: Problem with rtrace in Windows/Dos
To: [email protected]
command line
dat, pts)
4- oconv also
cheers
aitor leceta
Date: 2013/2/27
command line
dat, pts)
4- oconv also
for the points in filename.pts
There probably should be a special message when the input doesn't match what's expected in rtrace. No one has really complained about it before, though I'm sure it's not the first time it has come up.
Date: February 27, 2013 9:56:35 AM PST
I wonder why rtrace´s stderr was not giving me any information.
cheers
aitor leceta
Date: 2013/2/27
i´am using radiance package installed via Diva for rhino 1.9 (i guess) in windows7 64 professional
I want to make some simple calculations like those i´ll describe via Dos command line
1- set the working directory where all my files are (obj, rad, oct, ies, dat, pts)
4- oconv also
gives me as result a file with just the header but no irradiance values for the points in filename.pts
It´s because i´m not using cygwin, i mean, is the problem with my radiance for window distribution? it woldn´t be the case as long as Diva is using rtrace for its calculations without problems. At least it use to...
