Thanks Roland, Martin for input,
I meant to make to reference to the Prism1 and Prism2 commands in the 3.5
release of Radiance. I am uncertain of the function file command line
mod prism1 id
5+ coef dx dy dz funcfile transform
n A1 A2...An where the new direction variables
So if I wanted to redirect light from a vertical glazed window down at an
angle of 45 degrees onto the working plane what values would I substitute in
for A1 etc?
* DxA DyA DzA and are the normalised direction to the target light source
* dx, dy, dz are?
I sketch of the dimensions would be very helpful, as I just can't picture
the above scenario.
Roland, Is it possible to use Prism1 or Prism2 commands in the PMAP version
of Radiance to forward raytrace from the photon port (the target light
(*luminance* source?)to the target illuminance source (the working plane)?
Martin, could is it possible to model a standard prismatic panel that
redirects vertical light from a light pipe for example, out at an angle of
45degrees onto the working plane? I will be testing one of the siteco panels
on my test rig so would be interesting to compare the results.
Anthony.
[mailto:radiance-general-bounces@radiance-online.org]On Behalf Of
radiance-general-request@radiance-online.org
Sent: 11 June 2004 21:04
Subject: Radiance-general Digest, Vol 4, Issue 9
radiance-general-owner@radiance-online.org
Today's Topics:
1. rholo & .hif files (O Graf)
2. Re: Fwd: errors from hdrgen (Martin Matusiak)
3. Fwd: Re: [Radiance-general] Fwd: errors from hdrgen
(Martin Matusiak)
4. Prismatic glazing in radiance PMAP (Anthony J. Farrell)
5. Re: Fwd: errors from hdrgen (Greg Ward)
6. Re: Fwd: errors from hdrgen (Greg Ward)
7. Re: Prismatic glazing in radiance PMAP (Roland Schregle)
8. RE: Prismatic glazing in radiance PMAP (Martin Moeck)
Message: 1
Date: Fri, 11 Jun 2004 12:21:53 +0100
Subject: [Radiance-general] rholo & .hif files
Message-ID: <1086952913.40c995d153a11@sms.ed.ac.uk>
Content-Type: text/plain; charset=ISO-8859-15
Hi!
What is actually the trick for setting the right values for the 'section'
variable in a .hif file? The rad-file which I use contains a laser scan of a
real room and I have no idea what are the right values for the 'section'
variable. Every time I change the values the actual grid appears somewhere
in
the middle of the whole scenery and I get such warnings as
dev/ogl.hdi: no sections visible from this view
if I try to turn around or to zoom. I understand why these warnings come,
but I
would like to know how I can estimate the values for the section to avoid
the
warnings and to be able to see the whole room and not only 2 walls.
Another funny thing is that the whole room stands on its side, i.e. lines
that
are supposed to be vertical appear horizontal. First I thought the view
direction might be wrong, but if I run the same .oct-file with rview using
the
same view-file everything is perfect. In addition to the right view
direction
the rview-command produces colored images and rholo gives only grey values
from
the same .oct-file. Is there a particular reason for such different results?
regards,
Olga
Message: 2
Date: Fri, 11 Jun 2004 14:17:29 +0200
Subject: Re: [Radiance-general] Fwd: errors from hdrgen
Message-ID: <200406111417.29402.alex@juventuz.net>
I hdr'ed all ouf the 13 images in one go, and apart for some 'poor
convergence' (orders 1, 3, 4 and 5) warnings, it worked fine. There is
no apparent distortion.
I repeated the process using the manual mode of the camera rather than
aperture priority. Again 13 images (same room, scene was a bit different as
I
eliminated the sky in the framing) and I was able to compute a hdr. But the
alignment problem still persists, I use the -a switch to turn it off.
Later I took a couple more images and used the calibration data to compute a
hdr and read the luminance values off it. It turns out that those are
somewhat accurate so that's a good sign!
However, I'm still not quite satisfied. Obviously, the calibration procedure
is meant to give a most accurate static description of the camera, but I
used
the camera's automatic whitebalance correction, so that's a variable. My
question is a complete novice one: how does the whitebalance affect the
luminance? What can I do to eliminate this variable (if it is significant).
Martin
Message: 3
Date: Fri, 11 Jun 2004 14:21:55 +0200
Subject: Fwd: Re: [Radiance-general] Fwd: errors from hdrgen
Message-ID: <200406111421.55929.alex@juventuz.net>
I forgot to mention that my "cvs build" of hdrgen is from last week, so
there
could have been changes from the version you have.
Martin
---------- Forwarded Message ----------
Date: Friday 11 June 2004 14:17
I
used
Martin
Message: 4
Date: Fri, 11 Jun 2004 14:51:26 +0100
From: "Anthony J. Farrell" <anthony.farrell@dit.ie>
Subject: [Radiance-general] Prismatic glazing in radiance PMAP
Message-ID: <OJEGILOIGGNAEAODNHIICEEGCDAA.anthony.farrell@dit.ie>
Content-Type: text/plain; charset=iso-8859-1
I am trying to model a simple sheet of prismatic glazing, but am unclear of
the dimension variable set out in the PMAP user manual for the prism
command.
Could anyone please forward me a drawing or sketch of what this command is
based?
Kind regards,
Anthony
This message has been scanned for content and
viruses by the DIT Information Services MailScanner
Service, and is believed to be clean.
http://www.dit.ie
Message: 5
Date: Fri, 11 Jun 2004 08:09:17 -0700
Message-ID: <4EE8BCAC-BBB9-11D8-BDAA-000A95BB392A@lmi.net>
Content-Type: text/plain; charset=US-ASCII; format=flowed
Hi Martin,
I believe that hdrgen isn't coming up with a good response function for
your camera with this scene, probably due to the strong color cast of
the walls. Since hdrgen (and Photosphere) compute the responses for
each of the RGB channels, using a lot of colorful patch samples can
skew the result. I've never seen such an extreme example before,
though -- most walls are off-white so this hadn't come up. Come to
think of it, the tendency of cameras to super-saturate their colors
could spell trouble in such cases, and I probably should modify my
algorithm to avoid colorful patch samples.
Thanks for the image set -- I'll run some experiments on my end to see
if I can improve on this. It is important to fix the white balance
whenever you take an HDR sequence, as the camera in auto white mode
will alter the coefficients between exposures otherwise, making it
impossible to get a consistent result.
Date: June 11, 2004 5:17:29 AM PDTI hdr'ed all ouf the 13 images in one go, and apart for some 'poor
no apparent distortion.I repeated the process using the manual mode of the camera rather than
different as I
But the
alignment problem still persists, I use the -a switch to turn it off.Later I took a couple more images and used the calibration data to
compute a
somewhat accurate so that's a good sign!However, I'm still not quite satisfied. Obviously, the calibration
procedure
I used
My
significant).Martin
Message: 6
Date: Fri, 11 Jun 2004 09:18:46 -0700
Subject: [Radiance-general] Re: Fwd: errors from hdrgen
Message-ID: <03936172-BBC3-11D8-992A-000A95BB392A@lmi.net>
Hi again.
Well, I played around with limiting the saturation on patches, and it
only seems to make matters worse; I'm not sure why. I think it's
because you don't have enough unsaturated pixels in your scene for it
to work, but I'll have to perform some more experiments to determine
that for certain. For now, you'll just have to find a more "neutral"
scene to perform your calibration on, then save the response function
and reuse it for other scenes, which is what I've been doing.
Date: June 11, 2004 5:21:55 AM PDTI forgot to mention that my "cvs build" of hdrgen is from last week,
so there
could have been changes from the version you have.Martin
Message: 7
Date: Fri, 11 Jun 2004 21:11:56 +0200
Subject: Re: [Radiance-general] Prismatic glazing in radiance PMAP
Message-ID: <40CA03FC.6010504@gmx.net>
Content-Type: text/plain; charset=us-ascii; format=flowed
Anthony J. Farrell wrote:
of
command.
Dimension variable? If you're referring to the -ds parameter, that
affects the resolution with which the light source surfaces are sampled
during photon emission. Are you referring to the prism material or the
genprism command?
Roland Schregle
END OF LINE. (MCP)
Message: 8
Date: Fri, 11 Jun 2004 16:03:42 -0400
Subject: RE: [Radiance-general] Prismatic glazing in radiance PMAP
To: "Radiance general discussion"
Message-ID:
<84F05BA9118BBD4A8FC6409808CE266C113A1F@ENGRMAIL2.engr.psu.edu>
Are there any validations of pmap? If desired, I can make measured data
available for some prismatic glazings as shown at www.siteco.de. See
http://www.siteco.de/products/tageslichtsysteme/?currency=EUR&lang=en&javasc
ript=true Click on "large panel prism systems".
Martin, Penn State
Sent: Fri 6/11/2004 3:11 PM
Cc:
> Hi,
of
> command.
genprism command?
Roland Schregle
END OF LINE. (MCP)
Name: not available
Type: application/ms-tnef
Desc: not available
Url :
http://radiance-online.org/pipermail/radiance-general/attachments/20040611/8
3d558e7/attachment.bin
End of Radiance-general Digest, Vol 4, Issue 9
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
http://www.dit.ie
