please I need help. Whenever I run objpict or objview or rvu, I get the same warning each and every time:
/rpict/ (or rvu accordingly)/: warning - unknown object type "ashik2" /
This error repeats no matter what I try to preview, a simple chair or a more complex model.
The preview than is/is not produced - I was not able to identify the trigger.
I am new to Radiance (and Linux). I got aware of this problem since I reinstalled Radiance from the NREL Radiance releases (I did this because I realised I was missing some files).
If I do understand it well, ashik2 should be an anisotropic BRDF model, describing the appearance of a material, and it is a calculation model - so "something built in".
Please, how do I fix the problem? Can please someone explain what went wrong?
I also get an X11 error. /
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server //":0.0"
/This was already once discussed on the mailing list, but was not somehow resolved. I have tried to upgrade the graphic card driver, but with no impact. Please, did someone solve this?
rpict (or rvu accordingly): warning - unknown object type "ashik2"
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
I’m not sure about the first one, but your problem about X server :0.0 is possibly because the value for your DISPLAY number in your regular terminal doesn’t match your DISPLAY number in X11. I’ll give you some advice based on how it works on a Mac, but your mileage may vary. Open an X11 terminal window (for Mac I do this from the Applications/Utilities folder) and type:
echo $DISPLAY
Check what number is returned. If you’re the second user on the machine to start X11 it’s probably :1.0 so go into your regular terminal window and type
export DISLAY=”:1.0”
To make a more permanent solution you could make such an entry in your .profile or .bash_profile shell login/startup file. You might have to change it each time you restart your machine if your users log in by different order each time you restart (the DISPLAY values are assigned sequentially). You’re probably best off googling this or getting more expert advice specific to your system. But I could try help if you don’t find a clear solution.
-Chris
Interesting. Chris Rush gave a number of things to look at regarding the X11 issue; as for the "unknown object type" error, could you post a link to some of these scene files you're trying to look at, so I can try to replicate the problem? Also, what version of the NREL installer did you use?
The 'unknown object type' error is caused by reading in a frozen octree (generated with "oconv -f") on an older version of Radiance, before this type was added. You need to update your copy of Radiance from https://github.com/NREL/Radiance/releases
Chris has the right advice on X11.
Subject: [Radiance-general] Preview error - unknown object type "ashik2"
Date: April 21, 2016 2:07:46 AM PDT
Is there any documentation on how to actually use this material?
So far it is only mentioned in a release note and on some presentation
slides, but not explained at all.
What are eg. useful input values for "specular power"?
Cheers
-schorsch
Am 2016-04-21 18:39, schrieb Greg Ward:
The '_unknown object type_' error is caused by reading in a frozen
from https://github.com/NREL/Radiance/releases [1]
SUBJECT: [Radiance-general] Preview error - unknown object type
"ashik2"
DATE: April 21, 2016 2:07:46 AM PDT
_rpict_ (or rvu accordingly)_: warning - unknown object type
"ashik2" _
trigger.
went wrong?
server ":0.0"
The Ashikhmin-Shirley reflectance model is a kind of anisotropic Phong model made physically plausible. It's main advantage over the standard anisotropic model in Radiance is that it includes a Fresnel modifier, which I use for perfectly smooth surfaces. Best to read their original paper:
www.cs.utah.edu/~shirley/papers/jgtbrdf.pdf
I added this model to Radiance a few years back with help from Nicolas Bonneel, as we were trying to run some comparisons. Peter Apian-Bennewitz also had requested it, so it seemed worthwhile to add.
Subject: Re: [Radiance-general] Preview error - unknown object type "ashik2"
Date: April 21, 2016 10:34:16 PM PDT
Cheers
-schorsch
"ashik2"
"ashik2" _
trigger.
went wrong?
server ":0.0"
Paulína
Radiance-general mailing list Radiance-general@radiance-online.org http://www.radiance-online.org/mailman/listinfo/radiance-general
* The useful range of the exponents seems to be between 0 (fully
diffuse and 10000 (mirror-like). Between 5 and 100 looks like the
most interesting range.
* To create a plastic-like appearance, the specular reflection should
be desaturated.
* For a metallic appearance, the specular and diffuse reflections
should have a similar tint.
Remaining questions:
* What happens when specular and diffuse colors are vastly different?
I'm expecting something rather psychedelic... Do actual materials
like that exist?
* Do the diffuse and specular color values depend on each other?
Eg. should their sum be less than 1?
Cheers
-schorsch
Am 2016-04-22 17:10, schrieb Greg Ward:
Hi Schorsch,
Cheers
-schorsch
Yes, unlike the other Radiance materials, you need to consider the sum of specular and diffuse components to determine whether you are within physical limits. The standard "plastic" and "metal" (likewise "plastic2" and metal2") simply make a binary choice between colored and uncolored highlights. The "ashik2" type allows you full control. I don't know what materials this is useful, however.
Date: April 22, 2016 1:31:40 PM PDT
Very interesting, thanks.
My conclusions go like this:
be desaturated.
like that exist?
Cheers
-schorsch
Hi Schorsch,
Cheers
-schorsch
Its hard to tell from the images, but it does appear slightly brighter.
Cheers
-schorsch
Am 2016-04-22 23:15, schrieb Greg Ward:
be desaturated.
like that exist?
Cheers
-schorsch
Hi Schorsch,
Cheers
-schorsch
Hmmm... I guess it reflects about 22% more light, because of the way the specular reflectance reduces the effective diffuse reflectance in plastic2. The total reflectance is about (1-.26)*.56+.26 for plastic2, and simply 0.56+0.26 for ashik2.
Date: April 23, 2016 1:35:01 PM PDT
So does that mean that the right sphere in the slideshow reflects
26% more light on average than the left one?
Cheers
-schorsch
be desaturated.
like that exist?
Cheers
-schorsch
Hi Schorsch,
Cheers
-schorsch
Thank you all for help.
I have once again reinstalled radiance (5.0.a.8) - it seems to work now - no more ashik2.
Regarding the display/ x11 issue - still working on it - but thanks for the hint.
